Adjusting Ohlins Shocks
Old Oct 6, 2013 | 10:13 AM
SeniorChief56's Avatar
SeniorChief56
Veteran: Coast Guard
Default Adjusting Ohlins Shocks
I purchased a used set of the 3-4's from a HD member. Now I need to adjust them to my conditions. I have tweeked on the upper and lower adjustments, but I can not get them to where my bike rides comfortable....I called Howard and he told me that seeing I did not buy them from him he would not help me. Help!!
Old Oct 6, 2013 | 10:41 AM
fabrik8r's Avatar
fabrik8r
Did they originally come from Howard, because he custom builds them for the customer and the application. First thing you need to do is validate the springs are correct for your weight and model. Arbitrary tweeking won't get you there. Set the sweep valve at at 12 clicks from closed and leave it alone for now. Adjust the spring preload, to sag 1/3 total stroke. After you get the sag set, you can play with the sweep valve about 2 clicks at a time. Be patient, this is not a quick process, you won't get them tuned in 1 day. The info you seek is here, search the forum threads.
Old Oct 6, 2013 | 11:03 AM
12hdrk's Avatar
12hdrk
If you really want to get it right send them to Howard and have him take a look. He will likely charge you for his time, but you would know exactly what spring rate you have. If it is incorrect for you he may be able to fit new springs for you. Also, he can see if there is anything else to recondition. 20.00 for UPS each way plus Howard's time is a small price to get it right.
Old Oct 6, 2013 | 12:00 PM
grbrown's Avatar
grbrown
#3-3s here. Howard custom builds for each customer, which as fabrik8r points out includes providing suitable springs. If you are the same weight as the seller you got lucky, but if you are much lighter or heavier, you will struggle to get them just right for you.
There will probably be a little leeway, so do as fabrik8r suggests, which is essentially setting the shocks at a neutral starting point. There are a lot of us in here with Howard's shocks, but if between us we can't get them right, then 12hdrk's suggestion is the fallback.
Old Oct 6, 2013 | 12:02 PM
qtrracer's Avatar
qtrracer
Unfortunately you are dealing with some unknowns, spring rate and valving. You can set the do some messing around to find out of the spring rate is close. I don't have my notes for numbers so maybe someone else has them but here is the general idea. Length A -basically the unloaded shock length eye to eye. Length B -shock length eye to eye with the bike on the ground, no rider aboard, bike upright. Length C -shock length eye to eye with rider aboard bike upright. Ok rider sag is A minus C , and that should be around 30% of total shock travel(whatever Howards site lists as travel) Free sag is A minus B. This number after setting rider sag will tell you whether the spring rate is close or out of spec. If the free sag is too little the spring rate is too light. If the free sag is too much the spring is too stiff. Maybe someone can jump in and give you the numbers that are relevant to your application. The shocks may have been set up for an application too far from what you need that the spring and valving is wrong. Adjusters can only do so much and they cannot change spring rate, they can only change spring pre-load and minor valving adjustments. Maybe I'm wrong too, lol.
Old Oct 6, 2013 | 02:47 PM
jefla's Avatar
jefla
3-3s here. Should be easy to determine spring rate as Howard's springs are different colors. Unless your seller went for custom color, this should not be a problem to determine. I think most riders at about 200# end up w/yellow. I was told yellow are fine for me w or w/o a 130# passenger, so there's a lot of flexibility.
Do what fabrik8r and GRB said, you'll be fine. Set up is a handful to nail, just gotta be persistent and patient. Read everything relevant on Howard's site - more than once.
Old Oct 6, 2013 | 03:07 PM
fabrik8r's Avatar
fabrik8r
You could also read the part number on the spring and cross reference it on the Ohlins website or call Ohlins tech support. Most of the springs are available in black or yellow. Verify springs and holler back. There are a few other critical considerations prior to tuning. Shock install alignment to minimize stiction, and don't "crank" on the sweep valve, turn with only two fingers to prevent damage to the valve.
Old Oct 6, 2013 | 03:12 PM
1Canuck's Avatar
1Canuck
If the HD member purchased from Howard he would have installation instructions from Howard. These used to be on his website.
aside from what help has been given, it would be good for you to know if the shocks (spring) were built by Howard and for what weight rider and passenger and then compare that to yourself. As said if the spring is wrong you will never get it to perform.
A great shock must have the right spring choice . That is why off the shelf shocks are one size fits all and will work differently for each.
Old Oct 7, 2013 | 11:49 PM
sel53's Avatar
sel53
Kinda spooky ... you sound just like Howard's writing on here!
Old Oct 8, 2013 | 04:24 AM
grbrown's Avatar
grbrown
Wink
He has schooled a lot of us!
