Adjusting Ohlins Shocks
Old Oct 10, 2013 | 11:13 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by tcatnat
Thanks 1Canuck, now to decide which one fits my need.
#3-3 are stock 13" length, #3-4 a little longer, the other sizes a bit shorter. Howard has developed his own damping for Ohlins shocks, to suit our Harleys, using Ohlins components. Ohlins purchased from any other outlet will not have his magic touch! He has chosen letters to distinguish between the different versions of JRI.
I suspect most US riders are happy to buy JRI, as they are a US brand, however I have seen no evidence of them over here in Europe yet. Ohlins are European and we have plenty of agents for them over here, so especially for European customers they would be a better choice, as service is available locally, if required.
Old Oct 18, 2013 | 02:22 PM
tcatnat's Avatar
tcatnat
Quick question on installling these shocks. I started installing them and noticed on the removal of the first OEM shock that the bottom bolt was tight coming out and required more force than I expected to get the bolt out. I checked to make sure there was no weight on the shock so I figured it was just loctite and continued to take the bolt out.
Did the same for the top and then began installing the new Ohlins. Well, I could not get the lower bolt to catch the threads correctly, it keeps wanting to go in crooked. So for comparison I go to the other side and proceed to intall the other shock and within 10 minutes had the OEM off and new shock on no problem; this one had the nut on the lower bolt.
Back to the right side and cannot for the life of me get the lower bolt in. I obviously do not want to strip it and looked at the threads with a flashlight and all looks good. I adjusted the jack to make sure everything is lined up right and it looks good. I also just tried to thread the bolt without the shock on and it still does not want to catch the threads straight on.
Has anyone run into this before where a bolt does not want to catch the threads but does not looked stripped? I am so frustrated right now, this should have taken 30 minutes but I've spent that alone on one bolt.
EDIT: I got it on, false alarm!
Old Oct 18, 2013 | 02:27 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
Hard to say without seeing the threads
Old Oct 18, 2013 | 03:03 PM
tcatnat's Avatar
tcatnat
Sometimes it pays to walk away. After posting I went back for another try and was able to get it in almost effortlessly on the 2nd try. Both shocks on, now to work on the adjustments.
I literally spent 30 minutes the first time around trying to get the bolt threaded, go figure.
Old Oct 18, 2013 | 08:10 PM
sel53's Avatar
sel53
You probably found same as me ... the swingarm-to-frame bolt distance was a mm or so different left to right sides. I put on the long one first, then used the jack to compress just enough to line the other side up. If the shocks have length adjustment you can use that to make up for that. I just set the preload after installation, so the preload was equal side to side.
albngore
Jan 14, 2019 07:47 AM
whyrzwaldo
Jun 30, 2012 02:23 PM
marcparnes
Sep 8, 2011 01:59 AM
07RoadHawg
Jul 13, 2011 09:07 PM
strongwood
Apr 26, 2011 09:28 PM
