Compensator question
Old Dec 8, 2013 | 09:10 AM
hardheaded's Avatar
hardheaded
Originally Posted by ke5rbd
the bolt is bad about coming loose. The lock tite that comes on the bolt won't hold it sometimes. you have to use red locktite. If you let it run loose it can wear the splines on the crank and hub which would not be a good idea. Your chain tension er can cause problems too if it is loose or broke. The model you are referring to is obsolete as of 2014 models.
did you just add red loctite to the patch that's already on the bolt or did you clean the patch off of the new bolt first?
Old Dec 8, 2013 | 09:23 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by Wideglide103
Thanks for the heads up. Will definately be having it checked out!
Thanks! I'm thinking warranty should take care of it as well, unless they give me crap for doing my 1k service myself!
Just save your receipts.
Old Dec 8, 2013 | 09:34 AM
Jackie Paper's Avatar
Jackie Paper
TUCCI, is your primary chain tensioner hydraulic?
Old Dec 8, 2013 | 06:12 PM
ke5rbd's Avatar
ke5rbd
I clean it off with a wire brush first. I also soak up any oil in the end of the crankshaft with rag wrapped on a allen wrench or small screwdriver sprayed with brake cleaner.
Old Dec 8, 2013 | 08:21 PM
bradsULtd's Avatar
bradsULtd
Originally Posted by Retrop
Well kinda. For awhile there were two different stock numbers for compensators. One was for the original compensator and the other was for the SE compensator, which had some improvements over the previous version. Then like Tucci mentioned, about 2010 or 2011 they started introducing all new bikes with the SE compensator. At that point they reverted back to only one stock number for compensators and that was for the SE version, which made sense. So, if you have replaced your compensator since 2010 you more than likely have the SE version. Then as you know the most recent version of the compensator was introduced with the 2014 model bikes. It appears to have quite a few changes incorporated into it to aid in lubrication shortcomings of the SE version. In true Harley Davidson fashion it takes them years and years to make fundamental improvements. There are literally thousands of us out here who thought we were solving the compensator problem when we upgraded to the new and improved SE version. As it turns out, this was not the case as many are still having problems with lubrication fretting etc.
It was 2011-2013 when SE compensator came as std equipment...swapped out mine about a year ago to the SE comp...
Old Dec 8, 2013 | 08:48 PM
GPHDXLC's Avatar
GPHDXLC
He's right. Now the 14's have a newer improved SE comp. So now we need to call the SE comps from 13 and back the old style SE comp.
Old Dec 8, 2013 | 10:11 PM
GNrider's Avatar
GNrider
I hear a clunck when I shut off my bike and was told that can be the compensator. Any input?
Old Dec 8, 2013 | 11:43 PM
ke5rbd's Avatar
ke5rbd
Most likely.
Old Dec 9, 2013 | 06:32 AM
VTL nut's Avatar
VTL nut
There hydraulic uses springs in the bottom to set the new ratchet position when slack is detected in the chain. The non hydraulic used a fixed position to set tension. Not sure which his picture is. Could be hydraulic with the springs buried in the bottom aluminum assembly/
And for posts sake, the compensator is part of the basket attached to the crank.
The part Tucci took the pic of in the middle of his photo is his cam chain tensioner.
Old Dec 9, 2013 | 08:00 AM
Jackie Paper
Appears to me his tensioner is not OEM and manually adjusted. Just not sure. However, I had never heard of the hydraulic primary tensioner (least one like the cam tensioner with actually oil being pumped to a piston) you referred to in you previous post 6.
