It took riding a big heavy Ultra, but I can see it now. I picked it up a 09 Ultra few months ago thinking my wife would start riding with me, she hasn't. So I'm with two bikes now; the Ultra and an 09 SG to compare rides. I rode the Ultra yesterday in the gusty Oklahoma wind and the front end just kind of wobbles around. I don't feel it on the SG, but it's there on the heavier Ultra. I can see how the beefed up forks on the 14s make a big differnce.
Salvation is at hand! You can convert your bike to a similar top tree design, to cure that fork flex problem, by using a Custom Cycle Engineering TourTrac Tree kit.
With apologies for not first researching this question .. given that Ultras aren't that much heavier than SGs, do the CCE TTs improve the handling of an SG?
If worked on off road forks over many years and i can tell u now that its more about the oil amount. the oil weight. the spring weight and the damping. Its not just about the diameter of the forks. And in fact sometimes bigger stiffer forks give a more harsh ride. Ive seen it and experienced it over the years. Im not sayin the 14 forks are not better but it could be more to do with set up and u can duplicate the 14 forks or make the 13 forks better than the 14 forks and ride with some set up work done do them. Its an art in itself
mikeo, yes. I have been fooling with oil viscosities and have found the ride much better. Stock brake dive is ridculous. I'm always solo and weigh around 200. I'm happiest w/ a mixture of 30% sock 70% SE. I'll do the internals once I have a handle on what really is better.
The forks aren't really the focus of this issue, its the tree design. I agree the diameter of the forks is probably the least important consideration. While valving, fluid type and amount, springs, and proper tuning are all key elements to a good front suspension, the fundamental weakness in the touring front end is the lack of clamping on the top tree. The top tree fork cap bolts do not prevent the tubes from rotating in the top tree, nothing ties the upper and lower tree together to keep them from rotating out of alignment while under strain. I'd bet most of those off road platforms you worked on had clamping on the upper and lower trees.
I have a CCE kit, although I haven't installed it yet, but I expect it will improve the riding experience and handling of any 41mm fork dresser. The stock 'top-hat' top tree system provides very little torsional support to the two fork tubes, which the CCE kit puts right, just as the new 2014 tree design does. IMHO that improved top tree is more significant than the use of 49mm tubes.
