Sony radio
Old Oct 8, 2013 | 05:19 PM
wrenchguy24's Avatar
wrenchguy24
Default Sony radio
Im looking at going with a aftermarket sony radio
I have read many threads and I don't see any body running A sony with
The ARC Mpak 6 system I have the arc 125.2 amp
Looks like Ill have to make a bracket for top of radio to set the amp on!!
Anybody running this combo???
Other suggestions!!!
Old Oct 8, 2013 | 05:56 PM
0ldhippie's Avatar
0ldhippie
There are lots of guys running Arc Amps with aftermarket head units (see dragonfly). Many just use Velcro to mount them but brackets are better. Not sure if the Yaffe mount would work? Check out the Audio section.
Old Oct 8, 2013 | 07:10 PM
Mixter's Avatar
Mixter
I have the arc amp velcroed to my sony head unit. Works great!
Old Oct 8, 2013 | 07:53 PM
wrenchguy24
Which unit did you use??
Old Oct 8, 2013 | 07:58 PM
Skip's Avatar
Skip
I have a Sony installed in my 2005 flht. Used the Biketronics kits for mounting and adapting to use the hand controls. I use the RF amp but I just mounted it on top of the radio using industrial velcro. Never had the amp that you are using but don't see why you couldn't do the same.
Old Oct 9, 2013 | 05:31 AM
Pioneer74's Avatar
Pioneer74
Look at this radio install mount. Had a "shelf" on top to install an amp. A little pricy, but looks a lot better than most out there.
http://www.ebay.com/itm/251348797995
Old Oct 9, 2013 | 06:03 AM
VTL nut's Avatar
VTL nut
I run an Alpine 2X90 bridged amp, class D. Its a 4 X 45 or 2 X 90, don't recall the model.
It is about the size of a brick, and brackets were easy to tie into the existing radio mounts and strapped on top with plenty of clearance. Slick little amp for the $$$.
I also upgraded to the 7 1/4" J&M speaks and like em.
Shadowray
Audio Systems
Apr 11, 2016 05:06 AM
Gooey2
Audio Systems
Feb 26, 2014 08:20 AM
scumBAGGER
Feb 19, 2013 07:21 PM
Ricks07
Oct 27, 2008 11:57 PM
BillinNY
May 10, 2008 10:20 PM
