That reference does not show year/model/make. That gasket was not in mine when I did my pipe swapover, I verified with the dealer in their catalog and when it was apart I did not see it. (dealer had never heard of 3 gasketes on a 2011 limited (maybe I did not have it apart COMPLETLEY) and did not see it. The way I did it WORKED FOR ME maybe my dealer WAS FULL OF CHIT. I did not see the schematic you just showed me. The schematic the dealer showed me for a 2011 FLH model did NOT show that gasket. I went to the stealer to get new gaskets, I still have the new ones that I did not use in my shelf, I paid 6 something APIECE for em. The dealer ABSOLUTELY confirmed I did NOT need that gasket. But the schematic you just showed proves OTHERWISE. I DID not see this when I pulled it APART. If you are right, KUDOS to you for calling me out, I still do NOT ( or didnt see the gasket you are talking about) ( we may have done it diff. ways.) I STILL dont know if me or U are correct. I am only explaining my perception of chainging my headpipe. If I am wrong, I will be the 1ST to admit it. Stay safe BRO.
Thats my story, I AM STICKING 2 IT" sTAY SAFE BRO.
I did not have the pliers either for the rings near the flange. Can someone post up a pick of what those look like?! They were'nt bad getting off, but getting them back on took me and a buddy.
Due to my location, I have to switch back to stock once every two years for an inspection...SUCKS! But I'll have to live with it.
Thanks so much pny67 for taking the time with the detail!! Thanks all....just what I was looking for! Off to wrench.
Will let all know on the x-over gasket. Diagram looks like the one I bought my stuff from....basically if it said nut, bolt, gasket I got a new one. Only 8k on bike but no stealer within 1.5 hours.
Once again it still dont describe year/make/model, however it looks the same. I might be wrong because I did not remove the crossover, only slid it out and back on the new pipe, looking at your expanded pic, it does look like that gasket slides OVER the crossover and tightening makes it seal, so I stand corrected, sorry bout that and the parts guy I talked to seems like he is full of chit, lol. Thanks for the thx Mike, GOOD LUCK, let us know how it went.
67 pny, I have a 2011 Limited and can verify there is a gasket in the crossover because I managed to damage it. It probably does not need replacing unless you mess it up as its just a sleeve gasket between the two pipes and not a shaped compression gasket like the head gasket. It has a crooked angle to the connection and I got it a bit out of alignment when putting back together and gouged the gasket enough that the inside pipe would not go into the gasket.
My 09 as well. I changed the crossover gasket after doing my cam change. Was a ***** of a job to get it (nearly) all the way in. Never got there and had to trim some of the end that was sticking out. Worked fine - no leaks.
If I had it to do over I wouldn't bother changing it.
Just de-catted my 14. I found taking off the right foot board helped (front mounting bolt has a pinched nut on it so use some lubricant on thread when removing).
Was able to reuse gaskets.
Wish I had installed a deflector plate of some kind inside cat housing to deflect more exhaust to the left tail pipe.
