21" front wheel
2. Did you change out the back wheel or kept stock? If so, what size (ie 18x4, etc.)? 18x4.25 ride wright, with a 150 avon venom
3. What front wheel and tire did you get (ie, make/model/size 21x?) 21x3.5 right wright/ avon venom 120/70-21
4. Did you encounter any change in steering and handling? very slightly, took 2 mins to get used to.
5. Was there any dipping of a feeling of lightness when you or a passenger were riding? Nope
6. Did you make any changes to correct differences noted in question 3? drilled fender holes out so I could tweak fender for clearance
7. Did you lower the front end, if so what did you change out and install (ie shorter springs, Progressive Suspension Front Fork Springs, etc.) progressive mono tubes/lowering, lowered 1"
8. If you had to do it over again, what would you buy or do differently? Nothing
9. Did you modify the fork rake? If so, by how much and what did you use? Nope
