Liquid salt???
Thanks.
Another reason I don't ride in cold weather is black ice. A friend went down on some last winter. He wasn't hurt, but the damage to his bike was costly.
Wax it, ride it, wash it, and then ride it again!
You need to use a surfactant to break the surface tension created by the salt molecules, especially upon drying in cracks and crevices on you bike.
Most detergents include a surfactant, some are better at removing salt than others. Salt X or Salt Away found one that worked well and market it as such. Lots of water helps, But water alone will not remove all the salt. You need a surfactant. It does not take a lot, but you need to break the surface tension if you plan to remove all the salt residue.
Most laundry detergents include a surfactant. The best way to remove liquid road salt, ie magnesium chloride, calcium cholide, potassium chloride, and even sodium chloides, usually mixed with sodium or calcium magnesium acetate and calcium hydroxide is to dilute your detergent brand that has a surfactant and spray it in all the hard to reach places. A one gallon hand pump sprayer from the local garden store makes a great applicator. You can dilute the detergent 10 or 20 to one. Then plenty of water to rinse the loosened salt away.
While the salt is very soluble, unless you break the surface tension with a surfactant it will remain on your bike. Same for your vehicles, water alone only removes the visible salt, not the hidden salt.
Anyway, thats my story and I'll stick to it until I change it. It is how I clean my Road King after I ride in the awful, greasy liquid road salt just to enjoy a rare wonderful ride over the mountain passes in the winter.
How does posting that you don't ride in it help the original poster?
