Lift table question
Old Oct 31, 2013 | 06:03 PM
shakrr's Avatar
shakrr
Originally Posted by keith t
oops, fingers malfunction.......meant to say I don't have a lot of room and have read that some of you guys tip the HF on its side when not in use. Suppose the chock has to come off?? I also am thinking about cutting a section of the garage floor out and dropping the lift in so it sits flush when not in use. Just hope it happens sometime soon, whatever it is, really don;t like that floor
I was tired of laying on the floor also I recessed that lift from Clark in the floor and its awesome
Old Oct 31, 2013 | 11:36 PM
mccstevie's Avatar
mccstevie
Yes you can drop the rear wheel through the removable plate on the HF lift. The lift needs to be raised to the highest level with bike supported by a scissor lift under the frame. I have done this numerous times with my Ultra Classic on the HF lift. With the saddle bag guards in place there is no way you can drop the rear wheel and angle it up through. The rear wheel will fit through the hole and drop out under the table,an extra pair of hands would help greatly. If you do decide to go with the HF lift,make sure to pick up the better wheel chock while your there.
Old Nov 1, 2013 | 05:17 AM
jmacdonald5's Avatar
jmacdonald5
..my bad..forgot about people with bag-guards..I removed mine long ago..so for me...it's WAY easier to slide the wheel out the side at an angle..to get the wheel out the other way, by dropping it straight down, that lift, and bike has to be way-way-up in the air...no thanks
Big Dave
Nov 5, 2017 05:57 PM
lowebudget
Feb 15, 2014 09:06 AM
Whir
General Topics/Tech Tips
15
Feb 10, 2012 12:24 PM
StanfordMan
Feb 17, 2010 12:58 AM
kzman
Mar 16, 2006 11:10 PM
