Replacing Starter
Old Oct 31, 2013 | 05:11 PM
FL-kruzen's Avatar
FL-kruzen
Default Replacing Starter
I'm replacing my starter on my 2001 EGC. Seems pretty straight forward. Disconnect battery cable, remove outer primary cover, remove starter gear, remove starter and install new starter, replace starter gear, torq to spec, makes sure bolt is secured. Tighten up starter. Test fire the thing. And button up.
Anything I missed?
Old Oct 31, 2013 | 05:40 PM
smithbrl's Avatar
smithbrl
I've never changed a starter but I've read that part about removing the battery cables first is VERY important.
Old Nov 1, 2013 | 08:03 AM
grbrown's Avatar
grbrown
That sounds about right, having done mine a few weeks ago. I suggest you remove the battery from the bike, to be on the safe side!
Old Nov 1, 2013 | 04:35 PM
reg26's Avatar
reg26
Thats about it but at least on mine...A 2009 there is a metal dowel that you could loose if your not careful when removing and make sure it's on/in there when replacing
vasol
Sep 23, 2021 10:36 AM
shovelhead716
Shovelhead
13
Jun 30, 2020 07:56 PM
jakwi
Shovelhead
17
Dec 31, 2018 08:20 AM
jason8251
Electrical/Lighting/Alarm
Jul 27, 2011 03:23 PM
harleyboy63401
Jul 15, 2006 12:55 AM
