screaming eagle primary adjuster
Old Nov 7, 2013 | 08:37 AM
hardheaded's Avatar
hardheaded
Default screaming eagle primary adjuster
has HD made any changes to this? i seen this in the new parts catalog and it looks good.
Old Nov 7, 2013 | 08:40 AM
Ultra103's Avatar
Ultra103
One 1 star review on HD's website. I'll stick with Hayden.
Old Nov 8, 2013 | 08:12 AM
hardheaded's Avatar
hardheaded
nobody running one of these?
Old Nov 8, 2013 | 08:26 AM
Rickr01's Avatar
Rickr01
I researched this last month, both here and in other publications. The consensus is that this primary adjuster is very noisy among other issues. When I change my comp, I think I'm going to go with the Baker.
Old Nov 8, 2013 | 08:32 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Are you talking about the SE manual adjuster? http://www.harley-davidson.com/store...nsion-adjuster ..... do you really want to open your primary every time you need to make an adjustment to your primary chain? It's made for large displacement drag bikes.
Old Nov 8, 2013 | 09:38 AM
Sc0-'s Avatar
Sc0-
I am running it, have a few thousand miles on it and it is indeed noisy at idle. I like the design but not the noise, will slacken it a notch and see if it is quieter.
Old Nov 8, 2013 | 11:31 AM
Rickr01's Avatar
Rickr01
Behind the scenes, it is said to be an upgrade to correct for deficiencies in the stock tensioner which tends to ratchet the chain up too tight.
Old Nov 8, 2013 | 11:40 AM
soft 02's Avatar
soft 02
I went with the Baker unit. Better made and no noise. Not much shoe meat on that SE adjuster pad.
Old Nov 8, 2013 | 11:48 AM
shooter5074
But it's not an automatic adjuster like the 88 twincams had..... you have to open up the primary and adjust the chain, by hand like the old days like the 88 twincams.
Table 1. Primary Chain Adjustment
FreePlay Inches Millimeters
Cold Engine 5/8-7/8 inch 15.9-22.2 mm
Hot Engine 3/8-5/8 inch 9.5-15.9 mm
Old Nov 8, 2013 | 03:56 PM
jfarrar30's Avatar
jfarrar30
Go with the baker. I have no experience with the SE but rumor has it they are noisy. I had the Hayden and it made my chain waaay to tight and caused vibration as well as whine. I tossed it in the garbage. I just installed the baker and looks to be a top notch product. Quiet no vibration and no worries.
