Want to pick up a HD battery tender soon and was wondering if anyone has a ballpark measurement on the cable length from transformer to quick disconnect? Want to have an overhead drop cable from GD opener outlet and mount the tender out of the way rather than string across the floor. Thanks
It's only about 3 feet. There is another 3 feet of AC cord from the tender to the wall outlet.
My BT Jr has a 12' cord and I use a charging cord extension to do exactly what you describe. (Extends the wire to the bike, not the wall.) Charger is by the wall and the cord is strung over and hanging off the garage door opener. I roll it up and hang it when not in use.
The HD tender (non weather resistant) looks to also plug direct into wall. .need at least 6 ft. If this is what you have Shooter, I should be good to go. Thanks for replies and ideas.
From: Western Illinois, land of bad roads, and corrupt politicians
