Front wheel installation help
Old Nov 8, 2013 | 10:43 AM
Dizzy810's Avatar
Dizzy810
Now it makes sense that the instructions are different. That's kinda a big mistake on HD's part considering it is included in a kit for 08 and later.
Old Nov 8, 2013 | 02:09 PM
skratch's Avatar
skratch
Originally Posted by fat daddy
I should have mentioned that the abs spacer will rotate counter clockwise and stop when it gets to where it needs to be.
the abs spacer is on the same side as the axle nut (left). if you are tightening the nut, it will spin the axle and abs spacer clockwise and could potentially damage the abs wiring. thats why the manual has you insert a phillips screwdriver in the hole on the right side of the axle so that you can hold it in place while you torque it down.
peddler
Jun 26, 2014 06:30 AM
mattVA
Sep 1, 2012 09:14 AM
bbflhrs
Sep 26, 2010 09:35 PM
tweeker
Feb 15, 2008 05:56 AM
kdietz
Mar 23, 2007 01:45 AM
