Opinion and info please.
Old Nov 7, 2013 | 06:27 PM
marvo75's Avatar
marvo75
Default Opinion and info please.
Buddy of mine is looking at a 1998 road glide. Super clean,30k on the bike, really good price on it. Does that year have any bad flaws? I know it has the 80 in it but not sure if carb or efi. Which is better? Chime in on any info! Thanks...
Old Nov 7, 2013 | 07:02 PM
jmacdonald5's Avatar
jmacdonald5
...had a 98 Fatboy, so same engine..absolutely, one of the most rock solid motors HD ever built was the later year EVO's,(EVO's were used from 1984-1998). 98 would be the first year for the "Road Glide"...before that they were "Tour Glide's"...a slightly different version...the 98 could have had a Carb or Injection...if injected, it would be the early version of the injection system, made my an Italian company,(Magnelli-Moretti), and known as MM systems...that's the only weak part of the bike, they could be a little temperamental,..if it's a carb on the bike, your friend is all set!...good luck
Old Nov 7, 2013 | 09:20 PM
DTTJGlide's Avatar
DTTJGlide
The parts finder says they were all carbed, as they don't list a FI version. Should be a great bike if the price is right.
Old Nov 8, 2013 | 05:01 AM
jmacdonald5
..parts finder must be incomplete... FI was offered optionally on Road Glide in 98...
...here's one for sale if you want it
Old Nov 8, 2013 | 10:07 AM
0ldhippie's Avatar
0ldhippie
I would sure hold out for a twincam. While Evos were much better than pans/shovels the TC is that much better. The extra 10-15 hp means ya don't have to hop it up and evo support is dieing, as is what little support there ever was for MM FI. Evo came out in '84 so it is a 30+ year old design... The difference between my '94 RK and '99 RG was huge!
Old Nov 8, 2013 | 10:12 AM
dougbk's Avatar
dougbk
If it was carbed I and liked it I would buy it, the later EVOs were rock solid. If it is FI I would avoid it due to the MM FI that caused a bunch of people problems.
Old Nov 8, 2013 | 10:49 AM
JJHOG's Avatar
JJHOG
I had a 97 RK fuel injection. Never had one single problem with the FI or even the motor. Put over 80K on it before I traded it in on a '11 EGUC. All I ever did was change oil, primary chain, clutch plates and spark plugs. Oh yea, bunch of rear tires and half again as many front tires.
If the owner has already put 30K on the bike chances are any FI problems have been resolved. Condition of the motor and the rest however is subject to inspection and scrutiny.
Old Nov 8, 2013 | 10:58 AM
larsfum's Avatar
larsfum
I own a 1998 Road Glide. And yes, you could get it carbed, Fuel Injected, or an anniversary model (95th). It has been a solid bike, and it is injected. They are not difficult to maintain contrary to popular belief. I get compliments all the time, and ride with twin cam owners. The bike does a great job of keeping up, even with the 103's. They can take her off the line, but my 1998 catches them at speed.
The evo motor was the last for the touring line. They are basically bulletproof. Weaknesses are the base gaskets may weep if you do not warm them up. The paper gaskets can be replaces with newer copper that hold up better.
They are highly customizable for speed, but the jugs cannot be bored out much over 88-90 in. You can put lager jugs on her if you want to go over that. A different camshaft can get you more speed.
If I had to do it over again I would. She is a great bike that I bought at a great price.
Old Nov 8, 2013 | 11:01 AM
heavyd460's Avatar
heavyd460
I agree with most here....rock solid engine, and there is still evo parts all over the place if need be.
If you like the bike...buy it. I still wish that i had hung on to my '98 Dyna
Old Nov 8, 2013 | 11:49 AM
thrapy's Avatar
thrapy
FYI: If FI gives you a problem an you don't want to mess with it convert it over to carb...
