Exhaust muffler keeps coming off
Old Nov 9, 2013 | 12:09 PM
Imold's Avatar
Imold
Originally Posted by Rico Rose
Out of round because it was tightened too tight.
Try a new torca clamp they are only $8 at the dealer. And don't overtighten.
Ditto on too tight. I replaced one last week, thought that 45-65 ft lb torque (manual) was awful high, so I've been installing them on the low side, never had one get loose. But this clamp had been re-used at least twice before, and snapped before it even hit 45. Even a new one would probably break before it felt like it "bottomed out", if someone tried to install it that way without a torque wrench.
Old Nov 9, 2013 | 12:40 PM
2black1s's Avatar
2black1s
Originally Posted by Tirpitz
Use a piece of steel, thin and half moon shape as a shim and try that.
I've done this and it works although I've done nearly a full circle, not just a "half-moon". You can find some thin (< .010") galvanized sheet metal at any building supply, i.e., roof flashing, gutters, ductwork, etc. Just cut to fit. If you have this stuff laying around and the tools to cut and shape it it's worth a try. If not, just go buy some new clamps.
And as for the comments on distortion from overtorqueing, it ain't gonna happen. The clamp's design with the saddle that you tighten against will not allow the clamp to over compress or to strecth beyond its design limit.
Another post mentioned a torque value with an upper limit of 65 ft. lbs. That has to be a misprint as 65 ft. lbs. is way too high for any grade of 3/8-16 bolt. 40-45 ft. lbs. for an upper limit would be more like it.
Old Nov 9, 2013 | 12:53 PM
MURPHCC1's Avatar
MURPHCC1
had the same problem too........wasnt the clamp or out of round......it was the collapsing end of the muffler itself, where it has the slots at the very end, SE pipes had the little tab that fits into the other side of the tip, it was getting hung up by not being square and going in there correctly, ground it down and it slides in nice and tight now!!
Old Nov 9, 2013 | 03:07 PM
Imold's Avatar
Imold
I mentioned it, it's in my manual. But I agree with you, seems way too high for the size bolt, why I only torque to the bottom limit, 45 ft lbs.
Old Nov 9, 2013 | 07:38 PM
scooter1128's Avatar
scooter1128
i just had this happen when i changed my mufflers. bought new clamps, problem solved
Old Nov 9, 2013 | 10:49 PM
ALUCARD19's Avatar
ALUCARD19
Ditto Above I'm a tool/die maker new clamps every time I change mufflers, cheap price to pay.
Old Nov 9, 2013 | 11:29 PM
jackstrr's Avatar
jackstrr
new clamp
Old Nov 9, 2013 | 11:45 PM
Woodchuck's Avatar
Woodchuck
My left side muffler slipped off a couple of times early this spring. I took off the used clamp and "temporally" replaced it with two stainless steel worm gear type hose clamps until I could get to the Harley dealer to buy a new one. The new clamp is still in the bag since the hose clamps are holding like a champ.
I placed one right at the connection between the muffler connection and the pipe and the other one just behind it. I used a socket on the screw rather than a screwdriver and sequentially torqued down each clamp. I tightened the front one to the point that the worm screw jumped out of the clamp slot but was able to retorque it.
The next time the muffler comes off for maintenance I may use the new clamp but the hose clamp method seems to be working better for me. It seems like the run on torque for the Harley clamps is a bit much even when new.
paco12
Jun 3, 2017 09:09 PM
E-Cigrettman
Shovelhead
15
Sep 9, 2016 07:51 AM
jt metal
Jun 7, 2015 07:17 PM
RLH3175
EVO
Sep 11, 2013 12:53 PM
mizmazzle
Exhaust System Topics
Aug 2, 2011 05:28 PM
