Wheeldock wheel chock
Old Nov 13, 2013 | 08:35 AM
FL450's Avatar
FL450
Harbor Freight has two models of chocks. The good one is about $60 and looks to built at least as tough as any of the others with a similar design. When you roll over the chock locking it, metal never contacts the wheel and the fit is tight. It's about 30# of steel and easily holds the bike upright. Tough to justify spending $200 - $250 on the others.
Old Nov 13, 2013 | 01:23 PM
hd_rolling's Avatar
hd_rolling
That's what I have, and its tough getting the bike back out of the chock. I'm getting better but it takes a few tries and a lot of front brake work at the same time to try to get it over that hump.
Old Nov 13, 2013 | 01:43 PM
STREAK's Avatar
STREAK
yep.. that's what I am trying to avoid. I think the technique described sounds great, but I'm getting more aches and pains as I get older.. the less I have to work to get my bike out of the chock the better...
Wayne
Old Nov 13, 2013 | 03:14 PM
FloridaHarleyRider's Avatar
FloridaHarleyRider
Wayne
I have the HF chock and I found the trick is adjusting it so the front wheel just goes into the chock and the bracket stays level and doesn't allow the wheel to go too far forward and down. Hard to explain but makes sense when you do it. Also I bolted the chock to a 4x8 sheet of 1/4" plywood (you could bolt it to the floor) so that the rear wheel holds it in place when you pull out of the chock.
Old Nov 13, 2013 | 04:04 PM
STREAK's Avatar
STREAK
Thx for input... I think all in all I will just feel more comfortable w/ the wheeldock.. hate to spend the money, but would rather spend it than worry..
Old Nov 14, 2013 | 02:09 AM
mike5511's Avatar
mike5511
Unless you are using it in a trailer, I'd spend the money on a good jack instead. (Just my thoughts based on my experience......FWIW)
Old Nov 14, 2013 | 06:38 AM
FL450's Avatar
FL450
I think that you could make the ol' in n out easy as pie if you just set a piece of 1/2" plywood in the channel, raising the height of the tire in the locked position. As long as the pivot pin is the high point and you still have the over center action, it should work fine. You might need to adjust the stop back one setting as suggested because lifting the front of the chock up moves the back of the chock back.
Old Nov 14, 2013 | 08:11 AM
STREAK's Avatar
STREAK
I went ahead and ordered the Wheeldock Chock.. will give a review w/ my thoughts once it has arrived and I'ved used it a bit..
Old Nov 14, 2013 | 10:23 AM
hd_rolling's Avatar
hd_rolling
Good deal.
I'll have to play around with my HF chock, thanks for the suggestions and not trying to highjack STREAK, just seamed to work out that way. Mine is bolted down to my table lift, playing with different mounting positions is easy enough to try as long as the bike still locks in.
Old Nov 14, 2013 | 10:29 AM
hd_rolling's Avatar
hd_rolling
Curios, what size is your front wheel 17? And what hole did you use to mount the back stop? Mine is in the last hole to the rear now and just wondering what yours is set at?
Thanks
