Gaskets info?
Old Nov 12, 2013 | 11:08 PM
Diggler1182's Avatar
Diggler1182
Default Gaskets info?
I have a question, decided to powder coat all parts listed below as I'm installing my 103 stage 2 big bore kit. Can anyone give me information on gaskets and I-rings besides going directly through Harley?
Primary Cover, Derby Cover, 6 Speed tran cover, top tranny cover, both lifter block housing, lifter cover o-rings, and cam plate O-rings
Please let me know if you have any advice!
Thank you,
Tony
Old Nov 12, 2013 | 11:32 PM
Fast Aire's Avatar
Fast Aire
Former Sponsor
Many builders & shops use Cometic or James gaskets. Various levels of motor kits are available thru Drag Spec, Cust Chrome, JP Cycles & other sellers of after market products.
Old Nov 12, 2013 | 11:57 PM
bagman1's Avatar
bagman1
Ive always had good luck with HD gaskets, tried James once and after 2 attempts to stop the leak went back to HD. But here is some real stern advice on powdercoating your engine parts (if you dont already know this). Make sure there is no PC on the insides of the parts that will be in the engine, check very carefully when you get them back for overspray, the stuff is like sand. I had that crap wipe out my new Feuling oil pump, cam plate, lifters and my reusable filter. Powdercoaters dont seal off much these days and the stuff gets everywhere.
LokiBobber
Engine Mechanical Topics
Feb 20, 2014 10:35 PM
ernster500
Jan 9, 2014 01:20 PM
pokey074
Apr 18, 2012 12:40 AM
deadman77
Feb 4, 2009 06:59 PM
Trbolvr
Jan 5, 2008 05:35 PM
