SGS Adjusting Shocks
Old Nov 15, 2013 | 03:46 PM
ejvette's Avatar
ejvette
Default SGS Adjusting Shocks
Trying to figure out how this works per the manual I backed off the adjusting **** as far as it would go I weigh about 210 it says 1 turn for 220 and 2 turns for 230 so I decided to try 2 turns its quite a harsh ride on bad pavement but I assume more turns will only stiffen the suspension not making the ride any cushier am I correct? How many turns are you guys running?
Old Nov 15, 2013 | 03:49 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You are correct. I just put the 13" version on my RG and rode it this morning. 0 turns for my weight.
Old Nov 15, 2013 | 04:01 PM
mkguitar's Avatar
mkguitar
watching how you guys like these shocks.
don't forget to calculate for riding gear and junk riding in saddlebags.
mike
Old Nov 15, 2013 | 04:07 PM
offthewall's Avatar
offthewall
The chart based on weight is a good place to START.
But what I found was the lowest setting that doesn't bottom out gives the best, most controlled ride. That usually winds up being a turn or two less than the chart.
I've got a 2014 Limited but have the Premium Ride Low Suspension. Same rear shocks as the SGS. With the tour-pak on, no passenger, no load, 2 turns is perfect for my 190 lbs.
Old Nov 15, 2013 | 04:14 PM
barrygreen's Avatar
barrygreen
Actually I was cleaning the bike and playing with the shock while the bags were off, and noticed that as you turn it in you can actually watch the spring compress.
I am about 245 and run mine @ 1turn, nice ride for me.
Old Nov 15, 2013 | 04:37 PM
dh2683's Avatar
dh2683
190 here. Tried a lot of settings and the best ride for me is 0 clicks.
Old Nov 15, 2013 | 06:17 PM
keno's Avatar
keno
I run 200lbs and set it at zero turns for best ride. Love these shocks over my stock shocks
Old Nov 15, 2013 | 08:10 PM
Texas Rapier's Avatar
Texas Rapier
I have had the premium low shocks on my 2009 Road King for 4 years now. I'm 200 pounds and ride with them set a zero. With the wife on and 2 clicks an go.
Old Nov 15, 2013 | 08:20 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I just rode home. Zero as I weigh under 200 and ride solo no tour pack etc. The ride was nice. They could stand to be a touch softer but a great ride overall. Compared to stock shocks, night and day.
Old Nov 15, 2013 | 08:30 PM
convincor's Avatar
convincor
180#.. 0 clicks
