Clutch Adjustment Question
Old Nov 18, 2013 | 07:58 PM
wjohn453700's Avatar
wjohn453700
6th Gear
Default Clutch Adjustment Question
I’ve been going through the procedures concerning clutch adjustment on my 09 Electra Glide. The shop manual tells you to, after setting the adjuster screw, hold it in place while tightening the jam nut to the proper torque. Maybe I’m not seeing something here, but if you are holding the adjuster screw in place, how are you going to get the socket attached to your torque wrench over the thing to tighten the jam nut to the proper torque? I have pretty thick skin, so if I’m off in left field, let me know.
Old Nov 18, 2013 | 08:04 PM
Northern Glide's Avatar
Northern Glide
There are multiple iterations of socket tools (multi-head for example) that will allow you access to the allen head screw. Look around a good store tool section.
Old Nov 18, 2013 | 08:07 PM
Uncle Chester's Avatar
Uncle Chester
I just hold it in place with a allen wrench and then tighten the nut with a cresent wrench.
Old Nov 18, 2013 | 08:08 PM
Harleycruiser's Avatar
Harleycruiser
Box end wrench, snug it down good.
Old Nov 18, 2013 | 08:18 PM
ynots's Avatar
ynots
4 torque wrenches and I havent figured it out yet. I use a craftsman dog bone wrench and guesstimate the torque
Old Nov 18, 2013 | 08:23 PM
PROVIDER7's Avatar
PROVIDER7
Check out this you tube clip for clutch adjustment info:
Old Nov 18, 2013 | 08:41 PM
Jerry1834's Avatar
Jerry1834
Box wrench and allen….never had a problem.
Old Nov 18, 2013 | 08:43 PM
Northbound Southerner's Avatar
I use a spark plug socket. I put the allen wrench through the hole and use a regular wrench on the socket...
Old Nov 18, 2013 | 08:47 PM
12hdrk's Avatar
12hdrk
Offset box wrench and allen
Sent from my Galaxy Nexus
Old Nov 18, 2013 | 08:49 PM
FinalShot's Avatar
FinalShot
Just use a crows foot and make sure it is set at 90 degrees to the torque wrench so you don't multiply the torque values.
