Transmission interchangeability ?
Old Dec 2, 2013 | 10:24 PM
DanDman's Avatar
DanDman
Default Transmission interchangeability ?
Is it possible to install a SE 6 speed gear set part#33102-03A for a '01-'06 Touring,'00-'06 Softail in a '00 FLTR case? Can the case be modified? Or would I have to find '01+ case? Found a killer deal on a low mileage gear set.
Old Dec 3, 2013 | 05:24 AM
vzts4q's Avatar
vzts4q
Reading the install instructions it would appear that you can. Have you looked at them?
There are other parts required as well as a special drill plate for modding the transmission.
http://www.harley-davidson.com/en_US...ts/-J03483.pdf
Old Dec 3, 2013 | 07:35 AM
ddm502001's Avatar
ddm502001
I would consider Baker Trans before I went this route, theirs is a direct bolt in from 5 to 6 speed. Was considering that on our '03 before I went the 2012 RGU route.
Actually sat and worked the cost numbers, to get the engine I wanted with the trans and the bigger rear tire then modding the bike to fit it all in and make it look good was too far out to even consider as I am now enjoying much the same but in a assembly line machine. Even as I loved the '03 RK I moved on and up without spending way too much and still having a '03 RK.
Old Dec 3, 2013 | 12:49 PM
DanDman's Avatar
DanDman
I forgot about the PDF instructions, looked at the 33102-03A ('1-'06) and the 33101-03A ('99-'00) instructions. Looks like the difference may be the shift drum & top cover. I'll have to study them some more.
Old Dec 3, 2013 | 03:26 PM
grbrown's Avatar
grbrown
They have the parts lists in them both, so you can compare item by item, also cost any differences.
DanDman
Dec 2, 2013 10:22 PM
BikerV
Feb 12, 2013 08:39 PM
ScottyR
Nov 28, 2011 08:18 AM
cruise_carter
Aug 26, 2009 06:26 PM
Biker Dan
11
May 19, 2008 08:51 PM
