Looking for some feed back from folks
With either air cleaners.
My main concern is the issue about oil
On the filter element ?
The new SE and Ness are almost exactly the same and use the same breather vent set up. There is no real difference. The filter you choose should not effect the oil issue either...
The new SE and Ness are almost exactly the same and use the same breather vent set up. There is no real difference. The filter you choose should affect the oil issue either...
what about the ness inverted one ? Any better then scream eagle ?
All Stage 1 air cleaners flow more air than your stock engine can use. Just get what you think looks good from a quality manufacturer (so it will last)...Fuelmoto's billet set up is awesome. I like the DK set ups too...I would have bought one of those but got a great deal on my SE.
I know many folks claim running the oil tank low helps lower oil misting but I sure don't understand how?? It is an oil tank. Oil in the lower case should not change no matter how full the tank is.
On air filters, Ness is cast, Fulemoto is billet, SE is harder install. They all work the same. Pretty sure Ness and SE are made overseas, not sure on Fuelmoto. There are many others but your engine won't be able to tell.
