HQ Cam question?
Old Mar 15, 2007 | 09:40 AM
77Tulsa's Avatar
77Tulsa
Default HQ Cam question?
I was viewing the specs on cams and notice that HQ always has the Exhaust lift about .030 less than the intake. A lot of the cams are straight across. I am looking at cams within the .575 to .600 intake lift when I do my build. I know some of you have been researching the hell out of this stuff so any info would be appreciated.
Old Mar 15, 2007 | 11:55 AM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
Default RE: HQ Cam question?
ORIGINAL: 77Tulsa
I can't answer you directly about Harley cams, but I know in my Small Block Chevy 406ci, I have Comp Cam. The lobes are different lifts for intake and exhaust. I believe you do not have to have the same lift on both intake and exhaust. Science would tell you it's not a 1:1 ratio. What I'm trying to get at is there is a method to the offset lifts, and it works!
Hope this helps.
Denis
Old Mar 15, 2007 | 12:16 PM
PhilM's Avatar
PhilM
HQ uses an asymetrical lobe design on their cams, menaing that that the lobes are physically different shape and size. Most other vendors use the same lobe shape & size for both intake and exhaust and simply adjust the orientation. Using the asymetrical design is obviously more expensive from a manufacuting perspective and makes designing the grinds more complex, but for someone that knows what they are doing, it opens the door to increased creativity and conceivably better results.
Regarding selection, the answer has more to do with the "whole package" and just one piece.
I'd suggest a call to Doug, in order to get the best answer and recommendation. He can also explain the lobe design much better!
Old Mar 15, 2007 | 10:30 PM
maineultraclassic's Avatar
maineultraclassic
From what Doug told me, the cam design that he uses allows the cams to make better flatter torque curves and at the sametime make higher hp numbers.
He got very technical with me when we were discussing the differences between the Andrews 26G's I had and the HQ0034G's I was getting ready to install.
It is best to call him and talk to him yourself, he is very good at explaining things and will help you in the right direction for your build.
Steve
Old Mar 16, 2007 | 08:34 AM
wnogood's Avatar
wnogood
As a general rule, every cylinder head and intake/exhaust tract is "Manufacturer specific" and has its own inherent design flaws. I am not sure, but on a Harley, maybe the intake side is more restricted than the exhaust. If so, that would explain why the cam would need more lift and duration on the intake side to make up for design shortcomings in the intake manifold/runner/valve pocket/etc. Also, different engines respond differently to more lift/duration on the intake/exhaust. Fact is, it is more expensive to make a dual pattern cam, it will be more versatile, and Doug knows his stuff!
nogood o~`o
Old Mar 19, 2007 | 12:57 AM
planenut's Avatar
planenut
6th Gear
Call Doug
he will answer your questions,just did a 103 build with the hq 600 cam with all the trimmins,great stuff, he knowa his stuff
jon
Old Mar 19, 2007 | 01:13 AM
Hammer02's Avatar
Hammer02
The HD exhaust port doesn't require as much lift as the intake does to exhale the spent gas.
A lot of cams are the same but it's unnecessary according to some.....
I went with Dougs cam after the recommendations of two of the above posters and after talking to him one day.
nottaway
Engine Mechanical Topics
29
Apr 20, 2021 11:55 AM
Gunny20
Apr 7, 2015 06:59 AM
venturaoutfit
Exhaust System Topics
Jul 14, 2011 11:18 PM
Daehawc
Nov 25, 2010 12:03 PM
fuelmoto
Aug 26, 2010 04:34 AM
