Is it possible that I can just weld a block off plate over the port coming off the head pipe for the left side muffler so I can run a 2 into 1 setup ? Bike is a 13 FLTRX. Thanks
Sure you can, but why? A real 2:1 uses a larger collector and outlet than the stock pipe.
On a budget and saw an opportunity to save a few bucks, gonna remove the cat anyway so I figured while it's off why not, I like the looks of the single muffler setups better. On another not while I was just searching I saw that 2010's came with a 2 into 1 head pipe, could I use one of those and would it be any better than what I'm thinking of doing ?
If you have the time and tools why not.I have an extra stock header that I'm thinking of doing the same thing with.I think the smaller outlet pipe than a two into one could be rectified by running a gutted stock can then the outlet would act like the baffle providing necessary back pressure.I may be totallly wrong but in the end what would you be out? you'd end up buying a two into one anyway.
In theory it will work and I'm sure it will. Will it perform as good as a D&D or Pro Pipe, NO. Exhaust companies spend big money engineering systems for our bikes to produce great HP/TQ and a sweet sound. I would wait and save until you can get a proven performer.
I haven't seen a side by side comparison but from the pics I have seen online the 2010 2into 1 head pipe does appear to have a larger collector. I'll prob just go that route I have seen a couple used ones fairly cheap. Anyone know if my heat shields will work with them ?
