2010 SG - Broken Ring Gear
Old Dec 14, 2013 | 02:30 PM
aidimack's Avatar
aidimack
6th Gear
Default 2010 SG - Broken Ring Gear
Hi Guys
I just bought my SG about 5 month ago and after 8000 on the meter, I sent my 2010 SG for service, to my horror they discovered a broken ring gear tooth. (see the attached pictures).
Any of you guys experience this problem on SG?
Any recommendation on which brand to go for?
Attached Thumbnails 2010 SG - Broken Ring Gear-mack-large-.jpg   2010 SG - Broken Ring Gear-mack-2-large-.jpg   2010 SG - Broken Ring Gear-mack-1-large-.jpg   2010 SG - Broken Ring Gear-mack-4-large-.jpg
Old Dec 14, 2013 | 02:38 PM
Jackie Paper's Avatar
Jackie Paper
I have see some banged up ones from people getting confused on the start switch. These teeth are induction hardened. Does the face of the brake look like the same? Your's probably had a crack in it or either accidental starter engagement. I would replace it with OEM.
Old Dec 14, 2013 | 03:02 PM
aidimack's Avatar
aidimack
6th Gear
Hi Ripsaw,
Haven't seen the damage myself yet only from the pictures which they sent me.
Am told that they have ordered a Rivera Primo set as replacement.
Old Dec 14, 2013 | 04:09 PM
Jackie Paper
Sure they make good stuff. Just noticed your location. Do you have a Harley Dealer there? That is one fancy looking place...What's a hamburger and coke cost over there?
Old Dec 14, 2013 | 05:22 PM
Bingee's Avatar
Bingee
Harley doesn't sell ring gears for your bike. They tell you to replace the whole clutch basket with the ring gear attached. List for about $530. But you can remove the broken ring gear and replace it with one made by Evolution. They make great clutch parts. I believe it's their part 1010-1241. It comes with instructions on how to install it. Cost about $125-$150. I've done a few of them and it's easy. Note that the gears are press fitted on. So I cut off the old one with a Dremel. Heated up the new one and slipped it on.
Old Dec 14, 2013 | 08:59 PM
aidimack's Avatar
aidimack
6th Gear
Ripsaw,
there's main HD dealer here but takes forever to get any main parts, quoted me 4 weeks!!!.
We also have 10kg hamburgers if any one hungry after riding their HD!..
Victory Motorcycles just officially opened 2 days ago.
Old Dec 14, 2013 | 09:00 PM
aidimack's Avatar
aidimack
6th Gear
Bingee,
Thanks for your good advice but I don't think that HD mechanic here is capable..
Old Dec 14, 2013 | 09:21 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
The TC 96 and newer doesnt have a ring gear thats replaceable like the TC88's had....Last I knew you had to purchase a whole clutch basket with the gear from HD.
Old Dec 14, 2013 | 09:53 PM
Jackie Paper
Originally Posted by aidimack
Ripsaw,
That's 8 quarter pounders..too cool
Old Dec 15, 2013 | 09:29 AM
aidimack's Avatar
aidimack
6th Gear
Guys,
Look likes they replacing with set of Rivera Primo and got them put on Ultracool Reefer too.
Let you all know the status once its ready to 'Rock n Roll'..
