questioning self.
Old Dec 16, 2013 | 09:20 AM
shorty07ultra's Avatar
shorty07ultra
Default questioning self.
For those who have done there own cam swap how many needed to go get the spacers for the outside crank chain alignment. I checked mine multiple times and it was ok but when the manual has all the different spacers that could be used to true it up I feel that I didn't check right i mean how is mine correct and i dont need a different spacer than stock. Just wondering how many others didn't have to use spacers to adjust the sprocket alignment.
Old Dec 16, 2013 | 09:29 AM
rdc401's Avatar
rdc401
I have done two,mine and my friends roadking.mine used the the same stock one. The roadking I used one size up to get it in speck.i believe it just depends on the cam that you are using.
Old Dec 16, 2013 | 09:34 AM
voodoodrug's Avatar
voodoodrug
I didn't have to use a spacer(se259 cams)
That part of the cam swap did drive me a little nutz,checked and rechecked but was all good to go.No worries.
Old Dec 16, 2013 | 09:41 AM
shorty07ultra
Thanks for the replies keep them coming.
Old Dec 16, 2013 | 10:13 AM
12hdrk's Avatar
12hdrk
They are about 8.00 at the dealer for the set. I bought a set but didn't need to use them. Sold them and my can bearing tools to a forum member.
Sent from my Galaxy Nexus
Old Dec 16, 2013 | 10:34 AM
fenderzig's Avatar
fenderzig
I put the stock ones back in and checked it out. It was all in spec for me....SE255s in a '07 96CI RKC
Old Dec 16, 2013 | 12:54 PM
the warden's Avatar
the warden
Kept my stock one for my TW222s swap as it was within spec.
Old Dec 16, 2013 | 01:08 PM
Sam2010's Avatar
Sam2010
when I swaped mine mine was in spec with stock spacer
Old Dec 16, 2013 | 01:13 PM
shorty07ultra
I am starting to feel a little better now about my decision.
Old Dec 16, 2013 | 02:49 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Bolt the pulleys down snug, use any type of flat edge, check the gap with a feeler gauge and if the gauge does not slide under the flat edge, call it a day and continue with the install. I also bought the upper and lower width spacers for peace of mind and now their someplace on my work bench collecting dust.
Good idea on selling those with the removal/install tool......
