questioning self.
Old Dec 16, 2013 | 06:10 PM
X Iron Butt's Avatar
X Iron Butt
The cam is probably got the least amount of difference in tolerance than the stack up you get in the engine so most (not all) of the time the stock set up will be close enough. Some stock setups could use different shims or multiples of the shims that are put in the kit for your convenience.
Old Dec 16, 2013 | 07:49 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Used the stock spacer when I installed my 57H Andrews cams. Checked the spacing with the feeler gauge and was good to go.
Old Dec 16, 2013 | 07:54 PM
Junkster's Avatar
Junkster
Bought the whole set of spacers. Used the one, one size up and took the rest back to Harley. SE204's. All good.
Old Dec 16, 2013 | 08:16 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
My Woods / FM TW-777's were good to go with a stock spacer.
Old Dec 16, 2013 | 08:28 PM
QC's Avatar
QC
My kit came with the spacers, Had to use the next size up.
Old Dec 17, 2013 | 01:38 AM
Hogster 1's Avatar
Hogster 1
I did all the same as these guys...I think that on newer bikes that it is almost allways repeatable. Should Be, but it might not be. Check and measure the way it tells you in the YouTube video and you will be ok.
Old Dec 17, 2013 | 07:45 AM
CGP93's Avatar
CGP93
From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
Great thread! I'm about to do 48h's in my 96" - does anyone know if the stock spacers will suffice?
Old Dec 17, 2013 | 02:42 PM
HDV-GLIDE's Avatar
HDV-GLIDE
No one knows until they do the flat edge procedure outlined in the service manual.
Old Dec 17, 2013 | 06:38 PM
KRober's Avatar
KRober
3rd Gear
I had the same concerns....Checked, rechecked and checked again. It was within spec. TW-222 cams in a 2012 Ultra Limited
Thatguy1234
Engine Mechanical Topics
May 12, 2017 11:33 PM
Madcop
Jul 16, 2014 10:36 PM
Dyna7
Jan 6, 2014 12:10 PM
lt1tyrell
Exhaust System Topics
Sep 27, 2011 11:03 PM
bowa18
Mar 30, 2011 09:18 AM
