Headlight Delay Relay
Old Dec 16, 2013 | 10:37 AM
Cliff-AZ's Avatar
Cliff-AZ
Default Headlight Delay Relay
Hi,
I just installed an DDM 35watt HID two bulb kit into a Dual Halogen headlight.
Light is awesome, but occasionally, the light shuts off when I fire the bike up.
I would like to just install a delay relay to kick the light on after the bike is up and running.
Has anyone here gone through with this?
Thanks In Advance!
Cliff - AZ
Old Dec 16, 2013 | 11:20 AM
dh2683's Avatar
dh2683
Common problem with HID. Just put a accessory switch in line with the headlight.
Old Dec 16, 2013 | 11:25 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Or use a single beam and it leave it off until the bike is running.
Old Dec 16, 2013 | 02:04 PM
vickers1's Avatar
vickers1
Most of the HID companies sell an inline capacitor for this problem It plugs inline with no wiring.
I had that problem and this fixed it.
Old Dec 16, 2013 | 06:27 PM
Cliff-AZ's Avatar
Cliff-AZ
Thanks Gents.
I don't want to put a switch in line with headlight. I thought of that but sooner later I will forget and wind up riding with it off.
I have the Harley Dual Halogen headlight and don't have the option to switch to High Beams (turning off low beams) while starting because the Low Beam still stays on in high beam mode.
The inline capacitor is supposed to be for flickering while running, not to fix the extreme drop while starting a cold motor.
Has anyone installed a headlight delay? That's really what I'm hoping to find. Ive seen some people with Jap bikes running this setup and its pretty slick. You start the bike as normal and then 15-30 seconds later, the light kicks on!
Thanks Again!!!
Cliff
Old Dec 16, 2013 | 07:35 PM
FirstElectra's Avatar
FirstElectra
Default this one would do
http://www.newark.com/amperite/12d-2...|&CMP=KNC-GPLA
lots of different styles-sizes to pick from. hope this helps
Old Dec 16, 2013 | 08:11 PM
Blackhawks's Avatar
Blackhawks
Go to eBay and search for this relay.
DC 12V H3Y-2 Power On Time Relay Delay Timer 0~60 Second DPDT & Base Socket
It cost like $6.00 bucks shipped and works like a champ! I used it for the HID in my SG. You can set it to come on from 0-60 seconds.
Old Dec 16, 2013 | 08:21 PM
UltraClassicElectraGlide's Avatar
I like the idea of a headlight delay when starting up the bike; would this work for all headlights, including the OEM set-up? It would be great for reducing the electrical load until after the bike has been fired up.
Old Jul 6, 2015 | 09:47 AM
gsbuick65's Avatar
gsbuick65
Had anyone got a wiring diagram for the delay relay?
Old Jul 6, 2015 | 10:57 AM
mkguitar's Avatar
mkguitar
crane cams used to have a diagram on the website- an easy $15 mod.
A relay is used on the lighting circuit.
when the relay gets voltage on a wire attached to starter primary circuit, power is cut to the lights.
when the starter button is released, the lights get power.
probably easiest to do this near the fuse block
Mike
flicksport1200
Electrical/Lighting/Alarm
Jun 22, 2014 05:15 PM
blacksportster05
Jul 8, 2012 11:47 PM
sian0120
Jun 9, 2011 12:00 AM
DPete
Aug 4, 2010 10:52 AM
flyslow
Feb 21, 2009 09:04 AM
