how far on 3/32 tread
Old Dec 17, 2013 | 11:27 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Veekness
I reckon that some things that fall into the realm of common knowledge, common sense, & common courtesy don't need asking! The other thing, is how would anyone out here in the Web World be able to predict how long anything is gonna last?
Have you ever heard of a Ouija Board? .... DUH !!
Old Dec 17, 2013 | 04:02 PM
Fathead2003's Avatar
Fathead2003
I hydroplaned once on a new tire pulling into a gas station 10 minutes into the rain. If someone would have been exiting I would have t-boned them for sure. Sure makes you pucker!!! Buy a new tire!
Old Dec 17, 2013 | 04:26 PM
Veekness's Avatar
Veekness
There ya go! LOL
Old Dec 17, 2013 | 04:59 PM
decencyxdefied's Avatar
decencyxdefied
asked a simple question and get taken for a ****in retard.. I asked because there's a shop about 75 miles from my house that's offering 30%off tires
Old Dec 17, 2013 | 05:20 PM
btsom's Avatar
btsom
OK, here you go. Continuing on low tread has already been run into the ground and how far you want to go is your decision based on how you ride. So, how much more is left? The wear bars are at 1/32 and the law says you need a new tire then.
What was the tread depth new and how far have you gone so far? Then a little simple arithmetic gets you your answer ASSUMING the tread will wear at the same rate that it has so far. Example: My new rear tire started life with 11/32. That gives me 10/32 until the law says I must change it. As luck would have it, I got a large nail in it when it had 18,000 miles on it and it had 5/32 remaining. I had used 6/32 out of 10/32 of usable tread so 18,000 miles represented 60% of what I theoretically could have gotten out of it. Dividing 18,000 by 0.6 tells me I could have expected about 30,000 out of that tire, it was a Dunlop Elite 3. I replaced the punctured one with a new one and effectively threw away 12,000 of additional wear due to being a bit squeamish about zooming around at 75 to 80 mph, often 2 up on a patched tire.
So, if you know your original tread depth and how far you have already gone on that tire, you can answer your question yourself. Because no one else has that information or your own personal tread depth minimum, no one else can answer your question.
Old Dec 17, 2013 | 05:34 PM
binkman78's Avatar
binkman78
3/32's to go 75 miles, unless you hit a nail etc. (even on a new tire) you'll be fine.
Old Dec 17, 2013 | 05:59 PM
SanJuanRon's Avatar
SanJuanRon
I always change at 2/32. My touring bike ('11 CVO Ultra) with stock Dunlops (407/408) gets roughly 1,800 miles per 1/32 on the rear tire. Thus, if you are getting the same mileage and don't want to go beyond 2/32 that would leave around 1,800 miles. You should do your own calculations regularly. SJ Ron
Old Dec 17, 2013 | 07:54 PM
Uugly's Avatar
Uugly
Two things I don't f--- around with.. Tires and Brakes, both equally important.
Old Dec 17, 2013 | 09:22 PM
Guitardude's Avatar
Guitardude
Admit it, you knew better than to ask this crowd!
If had had said the part about 75 miles to save money, we woulda rode you like a .50 ***** for that, too
LOL!
Old Dec 17, 2013 | 09:33 PM
dirtdobber's Avatar
dirtdobber
To your tire dealer.
