ABS Wheels
Old Dec 17, 2013 | 03:17 PM
dfowler1's Avatar
dfowler1
Default ABS Wheels
Can non ABS wheels fit on ABS bikes and work with ABS? I have a chance to get non ABS wheels cheap and want to chrome them. What do I have to do to put them on my ABS bike? {2009 Ultra}
Old Dec 17, 2013 | 03:26 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Yes. You will need to install ABS bearings in the Non ABS wheels. A front wheel takes the ABS bearing on the left front, a rear wheel takes it on the right rear, 1 bearing per wheel. Harley is the only manufacturer of the ABS bearings.
Old Dec 17, 2013 | 06:36 PM
rleggs's Avatar
rleggs
The internal spacer is different due to bearing width also. Your dealer should carry an abs wheel bearing kit which will include the spacer.
Old Dec 17, 2013 | 08:29 PM
dfowler1's Avatar
dfowler1
Could I just use the ones from my stock wheels?
Old Dec 17, 2013 | 09:49 PM
Hogpro's Avatar
Hogpro
Former Sponsor
You could but I'd get new bearings. Peace of mind.
Old Dec 18, 2013 | 10:30 PM
davey019's Avatar
davey019
The spacer is different and from what I understand it will not fit. I just bought a set of wheels and they have abs bearings in them and need to go nonabs
Old Dec 19, 2013 | 06:53 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Yes you can use the spacers (internal and external) but I also agree to go with new bearings.
Install the ABS side first, insert the internal spacer, install the non-abs bearing just until it touches the inner spacer. Bearing bores should turn freely and smoothly.
Old Dec 19, 2013 | 09:03 PM
lp's Avatar
lp
Like Low Joe said the Internal Spacer is the same. It's the outside spacer that's different.
On an ABS bike the sensor (front left or rear right) is the actual spacer.
lp
mikeo33y
Harley-Davidson Street
Feb 23, 2016 07:23 AM
Skeezmachine
Apr 21, 2014 08:01 AM
jwk784
Mar 21, 2013 06:18 PM
fjoh
Jul 21, 2011 09:23 PM
UPSGUY
Wheels/Tires
Oct 25, 2010 07:58 PM
