They worked last night when I used them, then today they don't come on. Today I installed my Badlands LED's, I unpluged the wrong harness first, then the correct one to install the LED Equalizer, Coinsidental or what? I checked all fuses and none blown. Spot light rocker switch doesn't light up either. Any ideas?
That's exactally what it was! Thank you. Didn't figure it would be like my truck, high beams on, driving lights shut down! New to touring bikes and learning.
Thanks again.
My spots came wired to work with either hi or low beam but were not functioning about half of the time after I got my monotubes installed. Bulbs and fuses were still good however I had a bad connection at the 4-pin connection for the 4-pin connection used by the switch. After reseating all was well.
Wish they were wired independent, my friends Fat Boy is but it is also a 2000. I believe there is a law as to how many lights can be on at one time. Should probably move it over to the accessory switch..
Thanks again.
Originally Posted by RK_2014
Good call on the switch Uncle Larry
On the '14's it is a program change - no harness adjust, got it done on the 1000 service
