Remove for the powder coating process, then replace afterwards. I looked at Ronnie's HD parts fitch and it is not shown. But it was there on both my knuckles rear wheel as well my newer Agitator rear. May be some kind of casting hole plug to keep water out of the inner wheel hub since that outer rubber compensator area can get wet.
Reason: More info
Someone went to the trouble to design and manufacture, then install it! By all means remove it for refinishing your wheels, but I also would put it back in after.
