.....After looking up some costs it would seem that I'm looking at around $660 for the HD parts through Surdyke (Upgrade kit, cam spacers, gaskets and SE pushrods), $230 for an Andrews N series cam on ebay, and whatever an oil change costs. Am I missing something?
Add a couple more $ for the three seals, assy lube, and the extra bolts you will need for the tensioner housings on the cam plate. I just did my conversion and used the screamin eagle oil pump, it is cheaper than the "08-up" pump, and has more scavenge and pressure. I reused my 'B' lifters. I bought my Andrews 21's through Amazon. All other parts are genuine HD.
How do you like the 21's? I'm undecided between those and the 26.
I like them. The real difference between them is the 26's come on about 5-600 RPM's to the right of the scale than the 21's. I used the 21's because to be honest, the bike ('06 ultra) is gonna be used mainly 2-up, and on 2 lane roads with moderate hills and curves, and of course, interstate. Most of my riding, even on the interstate, doesn't go above 4K except for the occasional blast through the gears to 5K. My speeds are mostly 30-65 on the curvy, hilly 2-laners, and 70-80 on the interstates. There is enough power to go beyond this if needed, and I know both the 21's, and 26's are easier on the total life of the valvetrain because the lift is not super high.
What I did is take those factors into consideration, and made my last ride before conversion, looking at the RPM's in which I truly rode on an average basis. 90% of my time was between 2K to 3K RPM, right in the 21's sweet spot.
Don't call fuel moto. Geez. EBay has several sellers that offer a complete kit including your choice of conversion cams. Pick up a set of good inner cam bearings and the tools to remove and install and you're set other than your push rods if you choose to go adjustable. All the parts in the kit are genuine hd other than the Andrews cams.
Yes, I forgot: I picked up cam bearings from Amazon also, and rented the puller for the cam bearings from Auto Zone. I installed them using a mallet and socket, LIGHTLY tapping them until the bearing was flush with the lip on the back of the bearing hole. Was really easy. Personally not keen on EBAY kits but I am sure others have had OK luck with them. Getting your parts from Surdyke is a lot cheaper than places like fuelmoto.
Why not go with gear drive and get rid of the shoes altogether???? No more worries.
I spent a LOT of money on mine, I decided to upgrade the whole cam chest, went with S&S 509 gear drives and a Fueling cam plate, S&S Adjustable push rods were also used
That got rid of the tensioners and upgraded the oiling system, I always have good oil pressure even in the Florida heat. The cams are tame, good idle, good power from 2 grand to 5 grand, not a grind that is going to stress the top end IMHO
next upgrade is a Thundermax to replace my PCIII
I'll say this and probably unleash the hounds on me but NEVER tap on a bearing race especially with a metal object. If you bind up the needles in the housing you will have a disaster waiting to happen. Those can bearings are fragile as hell. It doesn't take much to bind the needles in the race.
I have a 2000 Wideglide with 42,000 miles and I switched out the cams and tensioners in January last year.
Since the bike lived 13 years and 42K miles I didn't think it was really necessary to go all hydraulic. I just replaced the cams with Andrews 21's and replaced the tensioner shoes with the ones from Cyco. (inner bearings replaced as well.) These tensioner pads are cheap, maybe $20 for a set or $60 if you buy the little tool they sell for install/removal.
I really don't get spending $500-$700 to replace a $50 20-40k maint. item. Ya are really are just saving maybe acouple changes with hyd setup and the extra cost of gears just doesn't compute unless ya plan on running 300+k? I must be missing something???
No hounds, but like anything in life, there are other ways. That being said, most people would use a metal hammer and whack away to install a bearing. IMHO, that is the wrong way. If you use a socket with correct diameter, extension, and while hold that firmly against the bearing case, then use rubber mallet and tap lightly, the shock on the bearing case is very minimal and often less then the pressure that the commonly used installation tool will put on the bearing case. It does not take much to get the bearing to move while installing. I have installed many bearings in many different applications this way and never had an issue damaging a bearing. Like I said, just another way.
