Cam install/removal tools
Old Jan 1, 2014 | 07:34 PM
mewalker0's Avatar
mewalker0
Default Cam install/removal tools
Just thought I would put this out there....I am looking to rent a set of cam install tools to swap out the cams in my 09 96 street glide. PM me if you would be have a set you are willing to rent.
Thanks.
Old Jan 1, 2014 | 08:06 PM
jmpancoast's Avatar
jmpancoast
Not sure if you'd be interested, but there is a forum member who make and sells a puller/installer for $80.00 shipped. I just purchased one from him. Here is a link:
https://www.hdforums.com/forum/multi...ombo-tool.html
Old Jan 1, 2014 | 09:25 PM
Teardrop's Avatar
Teardrop
I have used one of these tools with good results. Well worth the money.
Old Jan 3, 2014 | 08:30 PM
mewalker0's Avatar
mewalker0
Bought the set from him. Super nice and a deal I couldn't pass up. Why rent one when you can buy one fir the same price!
Old Jan 3, 2014 | 08:53 PM
RoadGlideGary's Avatar
RoadGlideGary
You don't need an install tool - use the end of the cam you removed. Go to the tool rental store and rent the puller. Did it on mine and so do others that know. Use plastic impact hammer on the install remember lettering is on the outside. Lube / soak bearings, place in baggie and store in freezer over night before installation, place on end of removed bearing and tap into place until seated. Easy as pie!
Old Jan 3, 2014 | 11:57 PM
$tonecold's Avatar
$tonecold
I won't rent them to you, but I will loan them to you. If you are interested PM me and I will give you the details. You will get the bearing removal and install tools, the gear immobilizer for removing and installing / torqueing the cam gears.
Old Jan 4, 2014 | 04:32 AM
just plain john's Avatar
just plain john
And that's what makes this forum so cool
Old Jan 4, 2014 | 07:51 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Use the correct tools. Tapping on a bearing race is asking for trouble. Sure, the bull in the china shop approach will seat the bearing, but when you understand the close tolerances inside the bearing race between it and the needles, you won't want to take a chance by blind tapping it into place. Continuing to "tap" the face of the race when the bearing is already seated lights the fuse for premature bearing failure.
The bearing installer tool mentioned is designed to seat those KoYo Torringtons to the proper depth and will not allow you to over-do it. Don't cheap out, use the correct tools.
Old Jan 4, 2014 | 07:55 AM
12hdrk's Avatar
12hdrk
+1 on correct tools
Sent from my Galaxy Nexus
Old Jan 4, 2014 | 07:59 AM
DinoM's Avatar
DinoM
+ 1 on what makes this forum so cool too!!!!!
