Your Opinion
Old Jan 5, 2014 | 11:47 AM
black panther's Avatar
black panther
Stage III
Default Your Opinion
Don't post often, but I do read alot of post. But I decided to give it a try. I am into touring with my Road Glide Ultra. Stock pipes but I do need alittle more bark. Nothing outrageous since the wife ride with me. Already suffer from ringing in ears due to military dutys. Can someone out there give me a few suggestion to help settle my mind. Thanks
Old Jan 5, 2014 | 12:01 PM
dribble's Avatar
dribble
That's almost like coming on here and asking what kind of oil to use. My suggestion would be to go to an event and listen to all the bikes there and choose based on the sound you like.
Old Jan 5, 2014 | 12:05 PM
Qdog002's Avatar
Qdog002
Just about any Slip on will increase the bark (noise) but if you already suffer from ringing in the ears I would think the quieter the better. If you do buy some slip ons, keep your old ones so you can go back if you don`t like the sound.
Old Jan 5, 2014 | 12:06 PM
rickb's Avatar
rickb
I would try decatting the head pipe than run a 1" 1/4 hole saw thru you stock pipe, you will need an extention on the bit to get all the way thru, than see how you like that. Than decide if you want to spend any more money.
Old Jan 5, 2014 | 12:09 PM
Senoj1's Avatar
Senoj1
6th Gear
Vance and Hines always has a solution for my needs. Done several bikes now and always hang Vance and Hines. Never any issues or problems. Have been on trips with dudes with other brands that seem to develop cracks, broken welds, discoloration etc.
8 years and 52000 miles on this Ultra Classic with V/H Baggers still no problems.
Old Jan 5, 2014 | 12:14 PM
pswomack's Avatar
pswomack
Cobra Powerport Headpipe and CFR mufflers are my choice, I've used many different brands through the years and have settled on that combo for my last 2 Baggers.
As suggested in a previous post, go to a local event or dealer and listen to some different setups that guys are running, and base your decision on what sounds good to you.
Old Jan 5, 2014 | 12:51 PM
AlanStansbery's Avatar
AlanStansbery
Black_Panther, I just put S/E Street Cannons on my bike. They're pretty mild as such things go. But still have a more aggressive sound than the stock slip-ons. I like them for the sound, but also because they're EPA/50-State legal and I don't have to worry about hassling a ticket.
At a steady cruise speed (70-80 MPH) they aren't much more, if any, louder than stock. Hear the radio fine.
Alan
Old Jan 5, 2014 | 12:53 PM
Bearcat1's Avatar
Bearcat1
You can always check out the Harley Screamin Eagle stuff. Just a little louder than stock with more rumble. Fuel Moto has nice options with their Jackpot mufflers. Comes in both 3.5" and 4" versions. They are pretty mild also if you still have a CAT in your header pipe which it sounds like you do. A nice feature here is if the mufflers are too loud stock then they make a quiet baffle option that is a breeze to change out. They will give you a slight boost in performance also if you do nothing else. Tons of options out there though. One thing I have learned is mufflers, seats and windshields are all personal preference. No one can answer what is right for you but you. Unfortunately that digs into your pocket book very often. Good luck.
Old Jan 5, 2014 | 12:57 PM
WB's Avatar
WB
Vancnand Hinds Monster Ovals.. These are what you are describing in your opening post. Low rumble with nice highway sound. You will like....
Old Jan 5, 2014 | 01:07 PM
steelerdude1's Avatar
steelerdude1
I love my Vance and Hines. If standard baffle is too quit for your taste you can run with no baffles, or if they are to loud, you can get a set of quiet baffles. Not certain if all of their slip ons have that option, but I know several do.
