What about putting a smaller baffle in the right side muffler and adding a full size crossover pipe the equal it out? Just by feel and sound. I've been wanting to try this but I'm sure others already have.
Problem is that then you're choking the system. Yes, you'd increase flow through the left side, but you'd be reducing it through the right (the easy way out) which would lead to increased back pressure, increased exhaust temperatures, and a pressure wave which would make reversion more likely.
Just a thought, my Rinehart tips are not interchangeable from left to right. There is two allen screws holding the tips in one on the bottom and another on the wheel side of each muffler.
I have the fuelmoto pipes and header, the mufflers have different baffles. The left side is more restrictive then the right unless I use the quiet baffle (which I was told to run in the right). Using these mufflers, you could switch the baffles, but doubt that you could feel a difference in doing so.
My old Dyna had a Thunderheader with damn near equal length head pipes and it worked real well.There are a couple more 2 into 1s out there that are similar and the stock 2 into 1 into two pipe on the Fat Bob is also damn near a straight copy of a thunderheader from the collector up.Not sure if any of this can transfer to a touring bike though.
The left side outlet is longer, there's a vicious crimp in the crossover, and there's two 90-degree bends in the pipe. The exhaust follows simple physics which means it takes the path of least resistance.
I went with a Jackpot header and full-sized crossover. That helps a bit, but that won't overcome those two turns and the length.
Originally Posted by mkguitar
the line from header to rt exhaust is a straight line
the lft exhaust takes a couple of 90ş turns.
think of the left side as an "overflow" when the flow exceeds the ability of the rt side, the left side will flow more.
on my exhaust system I swap the lft and rt side tips to equalize "wear" so they look more similar.
some systems are set up so that the 2 pipes are different- the left side may be smaller internally so as to keep velocity high
the key with exhaust is not just "flow" but also the velocity of the gasses.
high velocity is good
ike
I've read that a lot on this forum. And, it makes all the sense in the world. Now if I could just figure why my left side flows more than the right. Did it with the stock slip-ons, with the American Custom (stock slip-ons with baffles cut out), and now with my V&H Monster Rounds. Head pipe is stock, and still has the cat. You can put your hand down there and feel the difference, and you can really see it on a cool morning.
So what gives??
You have a mouse living in your right muffler outlet.
After installing Rinehart slip-ons on my Electra Glide, I notice that the exhaust pressure was greater from the front cylinder than the rear. Is there anything short of installing true duels to cure this?
You do not want to Cure it it is not a sick. They are designed that way.
It is called scavenging and it one of the best ways to get a Big Vtwin to run right and tune well. So called True duals are not the answer
