After installing Rinehart slip-ons on my Electra Glide, I notice that the exhaust pressure was greater from the front cylinder than the rear. Is there anything short of installing true duels to cure this?
The left side outlet is longer, there's a vicious crimp in the crossover, and there's two 90-degree bends in the pipe. The exhaust follows simple physics which means it takes the path of least resistance.
I went with a Jackpot header and full-sized crossover. That helps a bit, but that won't overcome those two turns and the length.
Even true duals are not guaranteed to give truly equal pressure in each pipe, for the same reasons mentioned - they are not the same shape or length. There are one or two exhausts which use equal length pipes, but they are also 2-into-1s and ain't the prettiest things around! They should however give improved performance, in the same way that the Buell equal length pipe systems do.
What about putting a smaller baffle in the right side muffler and adding a full size crossover pipe the equal it out? Just by feel and sound. I've been wanting to try this but I'm sure others already have.
I have read in this forum that there are some systems that have different baffling in the right versus left pipe...might want to go back and start checking some of those out. I hear ya re: annoying, it was something I noticed at first, but if you're seriously annoyed about it, just go get a two into one system, Thunderheader and V&H Pro Pipe come to mind, and be done with it once and for all, and you'll probably pick up some horsepower along the way. Yes, you'll have to re-map and tweak things a bit, but this particular issue won't annoy you any more.
Personally, it's something I've gotten used to. Just part of the personality of the scooter.
An Old Guy was telling me about the Panhead he campaigned in the early 50's.
he was a roaming traveler/racer and his transportation was his racer.
swapping heads and a reverse ground cam, gave him the exhaust ports on the inside of the motor, and the intakes on the outside of the motor (amal carbs w/ remote float bowls).
this gave him exact equal length exhaust headers which came around behind the rear cylinder into a 2/1 on the right side.
as he was racing he needed left side clearance which included a 1" block under the tranny to raise it up.
funny story and outside the box thinking in a day with no catalogs
Mike
