How much fuel...
Old Mar 18, 2007 | 01:27 PM
TwoBaggerz's Avatar
TwoBaggerz
Default How much fuel...
does the fuel tank hold?!? I found out the hard way! I didnt notice when the fuel light came on (first mistake)... I didnt stop to get gas before I got off of the main highway (second mistake)...
I have been getting 36-39 mpg...I guess my riding style is changing as the bike is getting broken in...the last tank I went 182 miles and it took 5.008 gallons to refill...I dismissed this as a gas pump error...Last night, after the fuel light being on for a while, I was within amile of a station, but looked at the mileage and had been 173 since fill up, I figured I could go at least 182 like last time (third mistake) well, a couple more stops and further from gas...pulled away from a red light and the bike almost died?!? I thought Uh Oh! About a half mile later it died! I coasted for as far as I could and pulled over, thinking I was gonna have to call someone to bring me some gas (and explain what a dumbazz I was). I leaned the bike as far as I could to the left for a few seconds thinking I had a little left in the tank. It started! I got on it has hard as I could to get some speed up, it died again, but I coasted to within 100 feet of a gas station...I leaned it over again and had enough to get to the pump!
Long story short, I went 175.6...no fuel left...and it took 5.160 gal to refill...(34mpg?!?) Not gonna do that again!
Old Mar 18, 2007 | 01:32 PM
2005UltraNC's Avatar
2005UltraNC
Default RE: How much fuel...
Been there done that.
Old Mar 18, 2007 | 01:41 PM
Two As One's Avatar
Two As One
Well atleast you made it , but that isn't very good gas mileage.
Old Mar 18, 2007 | 01:47 PM
Smokun's Avatar
Smokun
NEVER trust a Harley fuel gauge! I go 185 miles max before I refuel and reset the trip meter everytime. I have gone 200, butI was pushing my luck then. I don't even bother with the fuel gauge.
Old Mar 18, 2007 | 01:48 PM
bay13's Avatar
bay13
I usually look for the 160 mark, and when I fill up it's around 4 gallons, usually a little less. 34MPG is bad, I'd consider a dyno, or something to explain why you are getting 10MPG less than most.
Old Mar 18, 2007 | 02:22 PM
BREAD's Avatar
BREAD
I'm not one to push my luck or my scoot. I normally begin looking at the 150 mark to ensure the bike is moving under its own power versus mine.
Old Mar 18, 2007 | 04:01 PM
berettag's Avatar
berettag
I start looking at 200. Get 46 mpg on my 2000 Ultra. But now that I just had some 26g cams installed, and put on some V&H Basics, we'll see how that changes.
Old Mar 18, 2007 | 08:00 PM
Dave_E's Avatar
Dave_E
Your OWNERS MANUAL will tell you 5 gallons. When the low light comes on you have aprox 1 gallon left. How did you miss that caution light? [:@]
Old Mar 18, 2007 | 08:18 PM
pjbolo's Avatar
pjbolo
I have an 06 rkc, i usually fill up at about 180mi, the most i've pushed it was 192mi if i remember correctly it took 5.003 gallons it was still running when i pulled into the gas station....when i took the cap of and looked inside it was dry!! i guess i just made it..
the bike is stock except for v/h slipon's stage 1 air filter and race tuner..
dealer told me once the light comes on you have about 20 to 25miles...
Old Mar 18, 2007 | 08:25 PM
Arizona's Avatar
Arizona
Yep, on my '05 EG when that light comes on you'd better IMMEDIATELY head for the nearest station. I'd say 20 miles is about right til you're walking. I don't like pushing my luck that far!
My Stage II 95" EG Classic gives me about 35 mpg's at best... I've always wondered if this is what I should be getting or not. I don't ride it hard, I'm easy on it and most of my miles are on the freeway on a one hour commute each way, so I should be getting optimal mpg's out of my bike.
