Options
Old Jan 19, 2014 | 09:31 AM
Rway's Avatar
Rway
Tons of license plate bolt on ebay with about any theme you may like that you could cover the holes with for temp fix. I would put a rubber o-ring between the bolt head and fender to protect the paint.
Old Jan 19, 2014 | 11:38 AM
Veekness's Avatar
Veekness
Just put a bolt in the holes with an acorn nut on them...better than an open hole...or button head bolts, he could even paint the heads body color, would probably not be too noticeable.
Old Jan 19, 2014 | 01:06 PM
Rico Rose's Avatar
Rico Rose
Not too many options. If you are dead set on leaving the plate above the tail light you have to fill the holes or cover them. I vote for rubber plugs. Looks like Lionsm13 has them in the pic he posted on his tourpack lid.
Or go for a couple of those snazzy bullet hole decals. Lol
Old Jan 19, 2014 | 04:31 PM
grbrown's Avatar
grbrown
Lightbulb
Life is too short - rubber plugs, then ride and forget them.....
Old Jan 20, 2014 | 08:13 AM
smokindave's Avatar
smokindave
Doing this would cover the holes. You can get plastic plugs for the holes at Lowes. Go to the hardware section and look in the drawers at automotive hardware.
Old Jan 20, 2014 | 09:15 AM
SCJE8's Avatar
SCJE8
I think the plugs would be quick and easy...and they really do 'disappear' after a short time (meaning...once they are no longer the focus of your attention, you just don't notice them nearly as much as you do now). There is a lot of work and expense if you yank the fender to get the holes patched and painted.
Steve
Old Jan 20, 2014 | 09:26 AM
vickers1's Avatar
vickers1
Originally Posted by dburgjohn
The thing is I don't like the plate below. I prefer it in stock location. Not sure of LEDs, might still look like face. However a single 2nd break light might work.
The real question is: What do I like better, the plate above with 2 holes or plugs below or the plate below with no holes or plugs showing?
The only way to make it look right with the plate on top is to paint.
Old Jan 20, 2014 | 09:50 AM
RoadKing2438's Avatar
RoadKing2438
I would just put some plugs in them for now. Then later find a good air brush guy, have him paint some kind of nasty skull on there ( or design of your choice) or something using the 2 holes for eyes and then stick some colored leds in there.
Old Jan 20, 2014 | 10:02 AM
Pioneer74's Avatar
Pioneer74
http://www.harley-davidson.com/store...e-mounting-kit
Old Jan 20, 2014 | 10:12 AM
thirstybob's Avatar
thirstybob
Originally Posted by crimson13
Rubber plugs or and emblem as suggested above . I'd put it back till I could get the holes filled
Put the plate back.
