Knocking noise
Old Jan 19, 2014 | 09:54 AM
cam2zap's Avatar
cam2zap
Default Knocking noise
2007 Ultra classic, After I accelerate the throttle once or twice quickly and then release it, I hear a knocking noise in the engine. Does anyone know what the cause is? Thanks Cam
Old Jan 19, 2014 | 10:00 AM
mkguitar's Avatar
mkguitar
could be as simple as the primary drive chain slack- are downshifts and low speed operations ( parking lot speeds) sloppy ?
Mike
Old Jan 19, 2014 | 10:27 AM
hotline1's Avatar
hotline1
You should check your primary chain compensator mine went bad and sounds like was doing same as yours
Old Jan 19, 2014 | 12:52 PM
cam2zap's Avatar
cam2zap
Guys this happens in neutral...Sorry
Old Jan 19, 2014 | 01:19 PM
journeyman's Avatar
journeyman
Primary chain spins with the engine. Neutral does not stop it
Old Jan 19, 2014 | 01:28 PM
Stiggy's Avatar
Stiggy
Loose compensator nut knock would be at idle, no matter whether you blipped the throttle. (Sounds sorta' like a thrown rod.)
badbmwbrad
2014-2024 Touring Models
Dec 6, 2018 10:45 PM
RCermak
EVO
Jul 12, 2016 11:21 AM
MaxShovel
Shovelhead
Oct 19, 2008 08:43 AM
mike_oh
Apr 8, 2008 03:46 PM
67xlch
Exhaust System Topics
22
Sep 29, 2007 09:40 PM
