103,000 miles and running like a champ. Motor and trans all original. My set-up is described in sig below.
The only problem I've had is the Compensator. It was just replaced for the third time. In the '09s it was a design flaw so lots of failures on the compensator. They have redesigned the compensator and supposedly now it's been resolved.
The starter was replaced at 75k. Otherwise just routine maintenance.
A friend has a SE Road Glide over 250k. The engine has been rebuilt once. Outside of his former one way daily commute of 65 miles, he is an extraordinary tourer.
"with normal maintenance and no abuse, how many miles would you expect an engine/transmission to last before major costly repairs could be expected?"
The key here is maintenance. With that being said, maintenance is only as good as the person doing it. Major costly repairs can easily be avoided with proper diagnoses of any issues through the maintenance. Being proactive with the understanding of how your bike works can go a long way in keeping it in working order.
Can't over emphasize the importance of having a shop manual, even if you think you are not a mechanic, being able to read about your bike and how it's components function together will greatly improve it's longevity. There is no reason any HD cannot run forever with proper maintenance.
I've done a couple of searches on this subject and can find no direct answer. The question is, "with normal maintenance and no abuse, how many miles would you expect an engine/transmission to last before major costly repairs could be expected?" I'm thinking in the '09 thru '12 years for a touring bike.
What he says...
I work on heavy industrial equipment which is designed to run indefinitely based on doing certain maintenance work AND inspections at regular intervals. IMO Harley are designed the same way... there is nothing lightweight about them, they are made to last and be rebuildable.
Maintain it well and limit modifications to something resembling stock and they should last indefinitely.
Our club has a loaner bike. A 2004 Ultra. It has 211,000 miles on it. The motor has never been opened up. Bone stock with stage1. It has a little valve noise but runs great!
Surely the cam chain tensioners have been replaced.
Not the year range you specified but my 95 ultra ran 168k trouble free miles when i traded it in. No smoke, plenty of compression. Oil change every 2500 with castrol gtx
Yah that and the shifter shaft bushing. Other than those two common problems, the 88s are bullit proof when taken care of correctly. The 96s have the compensator problem and that is about it.
Honestly I think the twin cams could run 100,000 miles on 10,000 mile oil changes provided they aren't abuse.
I know what the OP is asking, I've had three Harleys and I wonder sometimes what is the reasonable longevity of the twin cams. 100,000 is pretty good for any motorcycle.
