Removing cat
Old Feb 4, 2014 | 07:01 PM
DGRF250's Avatar
DGRF250
Default Removing cat
Thinking of removing cat. Bike is completely stock. Good or bad idea?
Old Feb 4, 2014 | 07:06 PM
twig's Avatar
twig
Depends on why you want to remove it does the heat bother you, looking for some performance gains. I just bought V&H true duals for my SGS only to get rid of the heat.
Old Feb 4, 2014 | 07:30 PM
DGRF250's Avatar
DGRF250
Heat is one of my concerns,and I'm thinking I will get better sound also.
Old Feb 4, 2014 | 07:43 PM
rockajet1's Avatar
rockajet1
Better sound, less heat and better flow! What's not to like? No reason not to unless you're under warranty and your dealer looks for that. My local dealer doesn't care as long as the warranty issue is not related to the decatting.
Old Feb 4, 2014 | 07:50 PM
DGRF250's Avatar
DGRF250
I installed Vance and Hines slip ons on my Crossbones which removed the cat and the dealer never had an issue with it. I have researched this on here and haven't found much on just removing the cat. All info is appreciated.
I plan on cutting pipe open to remove and weld back.
Old Feb 4, 2014 | 08:44 PM
northeimcustom's Avatar
northeimcustom
Originally Posted by DGRF250
I have researched this on here and haven't found much on just removing the cat. All info is appreciated. I plan on cutting pipe open to remove and weld back.
Lots of info on here. Keep searching! But ya, that's what I did. Just removed the small heat shield cut it, gut it, weld. Super easy. Nothing but positive gains! Wish I would have done it sooner is my only regret !
Old Feb 4, 2014 | 09:00 PM
Webo's Avatar
Webo
My dealer was more than happy to install VH Power Duals on my bike along with the rest of the stage one hardware. I've never heard of anyone locally that had any warranty issues with a cat less head pipe. No if you put stage one hardware on and didn't tune the bike and burnt up the valves from running to lean you will have a warranty problem. But even that wouldn't be due to the cat removal...lol
Old Feb 4, 2014 | 09:43 PM
0ldhippie's Avatar
0ldhippie
I'd think of a tune to go with it, might as well do the A/C too.
Old Feb 4, 2014 | 09:49 PM
one-up's Avatar
one-up
Old Feb 5, 2014 | 06:11 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
You will lose some heat. Better sound...well, you'll probably get a different sound but it might or might not be better.
