Removing cat
Old Feb 5, 2014 | 06:29 AM
WILDWOOD_1124's Avatar
WILDWOOD_1124
I'm glad that I removed mine! I do miss the heat on cold rides but the sound is so much better especially after adding a tuner as well.
Old Feb 5, 2014 | 11:54 AM
DGRF250's Avatar
DGRF250
Thanks for the replies. I have learned a lot since I found this site.
I'm going to remove the cat and add XIEDS.
Old Feb 5, 2014 | 11:56 AM
SBates08's Avatar
SBates08
Originally Posted by DGRF250
Thanks for the replies. I have learned a lot since I found this site. I'm going to remove the cat and add XIEDS.
And the more you read, the more you'll learn, and the more you learn, the thinner your wallet gets!!!
2010 Limited with some stuff
Old Feb 5, 2014 | 12:43 PM
Hausguy's Avatar
Hausguy
For about $20 more you can get the Vieds which are adjustable to some degree. For a few hundred more, you can get a real tuner (PV, TTS, SEPRT) and get closer dialed in, AND have something that can grow with your mods if/when you do them.
You don't mention an A/C. Changing this out will add more performance bang for your buck.
Old Feb 5, 2014 | 01:26 PM
HDSAE60's Avatar
HDSAE60
I don't like cats. No cat here and it sounds better runs better and a lot cooler on my legs. JMO
Old Feb 5, 2014 | 01:29 PM
sg2007's Avatar
sg2007
Gutted mine two years when I bought my SG 2011, reduced heat, ok sound, but couldnt get it to run good.Added the Vieds, still the same.Pcv and better throttle response but not what I thought how it should run.Got rid of the PCV and just rode with vieds,then last month I installed Cobra Power Port headers to the exsisting setup.Wow what a difference,way better throttel response, smoother ride, very nice Harley rumble and better mileage..If I could id kick myself in the *** for not doing this in the beginning.Keep your OEM header and get an aftermarket one, you wont regret it.
Old Feb 5, 2014 | 02:14 PM
68beep's Avatar
68beep
So are you running stock mufflers with the Power Port Header?
Old Feb 5, 2014 | 03:16 PM
sg2007's Avatar
sg2007
No, im running Reinhart slips and SEAC.I also had the stage one d/l done when I first got it.
Old Feb 5, 2014 | 03:51 PM
DarceyE's Avatar
DarceyE
Originally Posted by northeimcustom
Just removed the small heat shield cut it, gut it, weld. Super easy. Nothing but positive gains! Wish I would have done it sooner is my only regret !
Are you saying you removed the head shield, cut, removed the cat and welded it back...all while the head pipe was still on the bike?
Old Feb 5, 2014 | 04:06 PM
DGRF250's Avatar
DGRF250
I'm kinda scared to ask but here goes, which tuner and can I install myself?
LIVINtheLIFE
Jul 6, 2018 07:55 AM
dviljoen
Exhaust System Topics
Mar 31, 2018 12:12 PM
waffler
Jul 30, 2007 04:16 PM
rkoko164
Oct 13, 2006 02:24 PM
Bluerose
Jul 7, 2006 10:12 PM
