Clutch not disengaging fully
Old Feb 16, 2014 | 08:50 PM
hornetguy's Avatar
hornetguy
Default Clutch not disengaging fully
It seems that my clutch is not fully disengaging on my 08 retired police roadking. After starting the bike, when I drop it in 1st gear, the bike will actually ease forward with the clutch lever fully pulled against the grip. It's more noticeable at some times than others.
I went through the clutch adjustment procedure this afternoon, and it made no difference.
Any suggestions on what might be the issue?
Old Feb 16, 2014 | 09:08 PM
EasternSP's Avatar
EasternSP
If this has only been happening since cold weather set in, its probably just the primary fluid running kinda slow till it warms up.
Does it still do that after the bike has been riden for about 20 miles or so?
Old Feb 16, 2014 | 09:33 PM
hornetguy's Avatar
hornetguy
Yes, it does it at different times, warm or cold.
Old Feb 17, 2014 | 06:29 AM
grbrown's Avatar
grbrown
When you adjusted the clutch, did you do so with the cable slackened right off? We've had several members who adjust the clutch centre without backing the cable off.
Old Feb 17, 2014 | 07:39 AM
big cahuna's Avatar
big cahuna
Being it's an old cop bike, the cable might be stretched past it's limits. I've also had that happen with my old Panhead, but that was a dry clutch and it had two warped clutch plates.,,
danny54
Oct 21, 2012 02:24 PM
bigredwing
Sep 1, 2011 11:00 AM
TRacer
May 24, 2011 11:50 AM
ninetyzero
Feb 18, 2011 08:12 PM
JockWhisky
Feb 17, 2011 08:06 AM
