I have the MGS True Duals with a PV running their tune. No objectionable "popping", "backfires" or anything else. Some throaty downshift gurgle, but nothing I didn't like. Performance is great, sound is great, look is great. What else would you want in an exhaust system?
Fullsac and Fuelmoto aren't true duals.
Couple other options are Cobra and S&S. Both make H pipes that look and sound like true duals but perform better.
I had no complaints, I liked being able to check the A/F ratio of each cylinder or to hold the palm of my hand over the end to sniff for gas or oil smells, individually....I especially loved the stereo effect at a light...
True duals are a second rate option for HD And VTwiun engines they need the scavenging .
It just sounds cool o say true duals.
Try the fuel moto 2-1-2 go high flow if you have a big build other wise standard you know the difference.
V&H Fit, Finish & Performance
2003 True Duals & Monster Ovals
2013 Power Duals and Monster Rounds - 2009 head pipes with 18mm bungs at ports for wide band O2 sensors
To many of us, True Duals sound the best and the power loss is negligible to most. For those of us who want the sound of the TD, there are options out there to help negate the negatives of a true dual system. (see below) After having a TD system for 4 years and going back to a stock header with 4" Jackpots, I can't get back to TDs fast enough. I hate hearing the exhaust all on one side. I'm not familiar with the exhaust systems/options on anything newer than mine.
MGS claim:
"Dyno-developed by MGS to produce more horsepower and torque than the competition. In most cases a 15% gain at the rear wheel. Why compromise on quality, looks, sound, or power when you can have it all with MGS? The MGS True Duals are one of the easiest ways to bolt on additional horsepower and torque. OVER 12+ ft lbs of torque, and the power band is right where you want it, very broad, power right now with a flick of the throttle that doesnt let up until redline."
