I bought them one year tossed them away .very cheap I bought the load lock ones with strap that goes around the wheel . now selling them cause I got rid of the trailer
that one would work great in a trailer, but the black one from HF can be used in your garage.
I bought the HF lift table and one of both chocks just to make sure I had at least one that would work.
A friend came over and we removed the front wheel vise and installed the smaller wheel chock.
My 2000 Ultra fit in it OK and we relocated the tie-down hooks to make the bike and lift more stable.
I plan to use the heavier wheel chock, mounted to a large piece of plywood for more stability when I'm cleaning my bike in the driveway.
That black one will give you a hernia on a Ultra. The skinny front tires work fine in them. The fat Ultra tire doesn't fit down in the tip up rear holder and you have to lift the bike 3 or more inches when unloading. I have 3 of the silver ones and they work fine. Tip up follows the tire around when riding into it and doesn't get close to the fender until you are in. The problem with them is the rails where they go by the brake rotors is very close. Mine were less than 1/4 inch clearance. Took couple of pry bars and spread them to get about 1/2 inch of clearance. I haul 2 FLHTK's and they are little different that the SG.
