Lean condition?
Power stoichiometric?
Holy *****......
OP, your bike is fine as is. Are you happy with how it runs? If you'd like to have your bike run smoother, cooler, and stronger you can add a tuner which will allow you to make the necessary changes to your ECM to achieve those things.
The Namz kit will do nothing but add an nearly insignificant amount of fuel to the area(s) of the map that need it least. It's not what you're looking for, and a waste of money.
this is more likely to occur when pulling loaded up a grade ( not like you have any grades near you) or dragging a trailer.
it will sound like pebbles in a coffee can and is usually momentary as the ECM will detect it and retard ignition timing.
however this retarded timing will usually cause the rpms to drop ( less power produced per stroke)...and the rider to downshift.
those of us who DIY and know how the system works can take readings from the o2 sensors with a voltmeter and from that know if the mixture is rich, lean, stoich etc and under which conditions, rpm, speed, load, temperature
In my case I have a 96" and a ness big sicker, no cat headers and supertrapps.
and I needed tuning compensation.
I use nightrider.com xieds, cost is the US under $125
Mike
Mike
under conditions when spark timing is retarded, less power per stroke is made*.
so if the bike is pulling a load...the rpms will drop.
at which point most riders will downshift...rpms raise, mechanical advantage is gained and the spark timing will then be more advanced and more power per stroke.
Mike
*it takes about 3000 milliseconds for the fuel/air mixture to burn ( not "explode") and expand in the cylinder, pushing the piston down the bore.
as rpms increase, the spark timing is "advanced" so that the expanding gasses are pushing the piston down the bore at the optimal time for the most force.
too early and the piston is coming up and the expanding gasses will try to push the piston back down shocking the crank**, rather than over the top and down.
too late and the moment is lost.
kinda like you trying to kick a bicycle pedal which is rotating.
at low rpms retarded timing can enhance torque, on my '53 FL spark timing is controlled by the rider with the left grip- on old cars, spark timin was often controlled by a lever on the steering wheel.
The operator is far more active on an older machine.
** this is why lugging the motor can turn lower end bearings to dust
The 96" EFI also makes more power per cc than the older bikes (the 74" panheads make about 38 HP at the rear wheel).
The motor may be hotter without xieds, but I didn't measure- i bought it in October so had 6 or 7 months before it got hot.
The biggest difference for heat is fairing lowers on the bike decrease oil pan temps by about 25ºF ( 12ºC ?) measured on a 105º ambient day. this is a result of increased airflow over the motor.
BUT that removed heat can feel like a blow dryer on the right thigh
performance: the xieds really only affect the ECM under part-throttle cruising conditions. which is about 90% of riding.
When whacking the throttle open ( WOT/ WFO) or when starting a cold bike, they are less active as the ECM is prioritizing input from other sensors.
This means that WOT takes the o2 sensor out of consideration and the rider could get some nasty pinging.
on my bike ( 09 FLHTC, 96"), when completely stock and after break in ( 5000 miles ( 8000 km), my bike would persistently ping under load- 2800-3200 rpms up 6% grades. We have alot of 6% grades in Arizona.
installing xieds solved that- and i ran that way for about 1000 miles.
then I swapped to hi flow exhaust for 1000, still to good result.
and finally to a high flow air cleaner, at which point the increased flow into and out of the motor gave a useable power gain. and still no pinging about 10,00 miles later.
I leave my Harley's at stage 1.
a rider looking to add cams or headwork later could instead look at installing a tuner system which can be adjusted as the motor is modified.
The fixed value xieds on my bike enrichen the mixture about 8%, the rev limit is unchanged.
This approach only affects the air'fuel mixture- as pointed out below by Fabrik8r, many other factors may effect pre-ignition.
how do it do?:
o2 sensors ( once heated above about 600ºF) on your 2007 react to the exhaust gasses so as to produce voltage, this voltage from the sensor is read by the ECM and the ECM bases fuel mixture based on that. the Xieds are simply a resistor network which slightly reduces the voltage to the ECM.
The result is that the ECM makes the mixture slightly richer than it would normally be.
Usual voltage produced under stoich is .45 volts DC
if the ECM "saw" .4 volts it would add fuel, if it "saw" 5.5 volts it would reduce fuel.
this can be measured in real time with a voltmeter and i am sometimes seen running around my neighborhood with a big Fluke meter taped to the bars on a Classic and an o2 sensor in the exhaust. my old Cadillacs also get o2 sensor bungs welded in the exhaust when work is done.
slight resistance from bad wire connections from all the sensors ( most run under 5 volts) or at the ECM connector ( or the added connection of a piggyback tuner) can cause interesting problems
mike
OP before buying anything else, get yourself a pair of waders and a BS filter.
There's much more to engine detonation than "too lean", and you can't do squat about it without a real tuner.
