Clutch Question
Old Feb 23, 2014 | 10:57 AM
JDSporty's Avatar
JDSporty
Default Clutch Question
I have trouble at times with finding neutral on my 2012 street glide. Also when I fire the bike up for the first time before a ride, the bike lurches forward a little with the clutch pushed in. Is this a sign that the clutch needs adjusting?
Old Feb 23, 2014 | 11:02 AM
DTTJGlide's Avatar
DTTJGlide
Yes it is.
Old Feb 23, 2014 | 12:48 PM
mwegryn's Avatar
mwegryn
Yep, it's not disengaging completely. Have it done before you ride anymore. A buddy of mine let it go and burned it up in less than 1,000 miles.
Old Feb 23, 2014 | 01:02 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Do it yourself it's pretty easy
Old Feb 23, 2014 | 06:11 PM
doc ock's Avatar
doc ock
Clutch adjustment and check the primary chain while your at it, might need adjusting too.
Just noticed you have one of those new machines with auto adjusting primary.
Old Feb 23, 2014 | 06:36 PM
stro1965's Avatar
stro1965
Redline Heavy Shockproof in the tranny makes neutral easier to find too. At least it does for me, shifts like butter.
Old Feb 23, 2014 | 07:28 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
A little bit of caution, make the adjustments on a cold transmission. No engine heat on it. Adjusting a warm or hot tranny will give you some problems on the clutch finding neutral.
Old Feb 23, 2014 | 07:36 PM
12hdrk's Avatar
12hdrk
+1. Let it sit overnight. Most dealers adjust hot even though the manual specifically staets cold. I guess they can't wait the four hours+ for it to cool sufficiently. Another reason to do it yourself. Mine was never right from dealer. Did it myself and it's correct. Follow the procedure (service manual) to put slack in the cable, then adjust the pack. Other folks have some different procedures, but I followed the bible and it works fine.
Old Feb 23, 2014 | 07:39 PM
'05Train's Avatar
'05Train
You will find that the bike will lurch forward when you put it in gear if you haven't ridden in a while and the fluid has drained off of the clutch plates.
Old Feb 23, 2014 | 08:21 PM
Juice's Avatar
Juice
easy to do
mehurr
Dec 28, 2010 03:48 PM
ms3300
Aug 12, 2009 04:44 PM
dog155
Custom Models
Aug 13, 2007 09:55 AM
dog155
Aug 13, 2007 09:47 AM
dynalowride
Feb 12, 2007 12:11 AM
