Brake Pad Replacement?
Old Feb 23, 2014 | 03:28 PM
TSD's Avatar
TSD
Default Brake Pad Replacement?
What do you use to spread the caliper open when replacing pads?
Thanks, Tim
Old Feb 23, 2014 | 03:33 PM
petdoc94's Avatar
petdoc94
There are a number of options...There is a tool for it that is cheap or a small screwdriver, small C clamp...Do this very slowly when you do this. Be careful not to damage the brake pistons and I always take the top off the master when I do this...But there are alot of simple options if you are careful.
I actually just got done doing this on my SG....
Old Feb 23, 2014 | 03:48 PM
doc ock's Avatar
doc ock
First of all you don't spread the calipers apart. They are bolted together and will come apart once the bolts are removed. Once apart I use a c-clamp to press the piston back in but use something over the piston to protect it from getting damaged. You may want to use an air compressor to full removed the pistons and clean the calipers along with the pistons completely. Check the seals for cracks or tears.
Old Feb 23, 2014 | 05:21 PM
FXDXTSport's Avatar
FXDXTSport
I use the handle of a small crescent wrench. It has smooth, rounded edges so it doesn't hurt the pads (although that doesn't matter if your replacing them). Slide it between the pads even with one set of pistons, turn until they are all the way apart, then move between the other pistons and repeat. If you've never added brake fluid you don't need to take the cover off the master but you might as well because you want to check the level anyway.
Old Feb 23, 2014 | 05:32 PM
dSINtia's Avatar
dSINtia
Exactly... Perfect description and explanation of what to do, not to do and why.
Old Jul 30, 2015 | 06:36 PM
Bafulgaro's Avatar
Bafulgaro
I do like most, use a C clamp to compress the piston. Clean it all up while I'm at it.
Rickr01
May 23, 2017 10:15 PM
lhgdale
Aug 6, 2014 09:50 PM
waterman7474
13
Aug 7, 2010 11:33 AM
crepe
Wheels/Tires
Apr 19, 2010 04:19 PM
nikon
Nov 10, 2006 04:40 PM
