read brake pad replacement problem
Old Apr 8, 2010 | 11:02 PM
crepe's Avatar
crepe
Default read brake pad replacement problem
I have an 09 Dyna with floating, 2 piston rear brake caliper. I tried to replace the worn brake pads but ran in to a problem. As I have done on my previous Sportster I pushed the brake pad in order to retract the brake pistons. Once it came time to put the new brake pads there was not enough room to get both pads in. Dunno what happened. Perhaps I did not get the second piston to retract as needed, but there just was not enough room to put both pads in. I'll take it to the shop and have them do it tomorrow... sigh...
Old Apr 9, 2010 | 03:28 AM
grbrown's Avatar
grbrown
You may need to remove some of the fluid from the reservoir. If that has been topped up at any time when the bike was serviced, when you tried to push the pistons back in, the fluid doesn't have enough room to go to. Could be as simple as that!
When you get your new pads in bleed the brakes to flush through new fluid, if it hasn't been changed recently.
Old Apr 12, 2010 | 01:55 PM
crepe's Avatar
crepe
Grbrown, it's not the fluid issue. I had the master cover off.
After asking around it seems the double piston brake calipers need to have both piston pushed back at the same rate. It's likely that I pushed the rear piston back more than the front and caused the front piston to stick out. Apparently I should be using a brake caliper spreader tool for the job. Now only if I can find a motorcycle brake caliper spreader...
Old Apr 12, 2010 | 04:34 PM
grbrown's Avatar
grbrown
Cool
You have my sympathies! My front calipers are both 6-piston and they don't ever play ball. Just had them serviced by the factory (Harrison) because of the same problem. With a total of a dozen of them there are bound to be problems. With my 4-pot rear I have a total of 16 pistons to slow me down!
Old Apr 12, 2010 | 06:18 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
...it seems the double piston brake calipers need to have both piston pushed back at the same rate. It's likely that I pushed the rear piston back more than the front and caused the front piston to stick out. Apparently I should be using a brake caliper spreader tool for the job. Now only if I can find a motorcycle brake caliper spreader...
Often the problem...I use the old pads and a piece of flat stock to hold the one set of pistons in place as I push in the other.
Just remember to clean the pistons real well before pushing them back in or they tend to hang up.
Old Apr 17, 2010 | 02:01 AM
crepe's Avatar
crepe
wow that's a lot of pistons Grbrown.
Old Apr 17, 2010 | 03:35 AM
grbrown's Avatar
grbrown
Cool
Somebody had to do it!
Old Apr 19, 2010 | 04:19 PM
harleydavis's Avatar
harleydavis
+1......the easiest and cheapest method!!
harleyrider4300
Mar 30, 2018 10:16 AM
Krazy8s
May 15, 2014 11:20 AM
sbryant
Mar 11, 2011 10:53 AM
clarsen2020
Wheels/Tires
Jul 22, 2010 07:32 AM
SecondChance!!
Mar 23, 2009 09:57 AM
