I belive they would work...Those are the exact connectors that were on my 03 RK Classic...That is the standard 12 wire set-up (6 per side) with NO cruise control...If you have cruise it will not work unless you plan to not have cruise...Inside the nacelle you will find two plugs, one black and one gray that should plug right into these bars...
When you get these, you may want to double check wire locations with this but I will assume they were on his bike functioning correctly so it should not be a problem...the top two are what you have pictured...the bottom two plugs are with cruise..sorry this damn picture is too small....
